  distributor hold down clamp
distributor hold down clamp by chrstnrockr
Started on: 10-12-2014 08:06 PM
Replies: 2 (137 views)
Last post by: chrstnrockr on 10-12-2014 11:19 PM
chrstnrockr
Report this Post10-12-2014 08:06 PM Click Here to See the Profile for chrstnrockrSend a Private Message to chrstnrockrEdit/Delete MessageReply w/QuoteDirect Link to This Post
anyone know where i can find a distributor hold down clamp for a 1986 fiero gt ... or another model that would work?
Report this Post10-12-2014 08:48 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can use one off any year Fiero with a V6 or a 93-95 Camaro or Firebird with a 3.4 V6. Probably the 89 thru early 90's 3.1 V6 hold downs for the oil pump drive would work, too. The oil pump drive is just a dummy plug without the distributor head on it. I think they all use the same hold down.
Edited to add that I just went out and looked at the hold down on a front wheel drive 88 2.8 V6 and it has the same hold down as a Fiero. I would imagine it's the same as the 3.1's. So probably any V6 Beretta, Cavalier, Cimmaron Cutlass Ciera, Grand Am, S-10 or S-15, El Camino with V6 should be compatible. Maybe even the later 4.3 engines, too.
[This message has been edited by fierofool (edited 10-12-2014).]
chrstnrockr
Report this Post10-12-2014 11:19 PM Click Here to See the Profile for chrstnrockrSend a Private Message to chrstnrockrEdit/Delete MessageReply w/QuoteDirect Link to This Post
thank you so much!!!!
