  Rodney's Select cables for 3800 f23 swap?
Rodney's Select cables for 3800 f23 swap? by fieroaddicted
Started on: 10-09-2014 09:39 PM
Replies: 1 (355 views)
Last post by: hnthomps on 10-11-2014 08:33 PM
fieroaddicted
Report this Post10-09-2014 09:39 PM Click Here to See the Profile for fieroaddictedSend a Private Message to fieroaddictedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney has select cables advertised on his web page for use with the F40. My 5 sp shifter is set up for use with two getrag select cables. I have one that was on the car, but i still need one more to gear it up. Does anyone know if Rodney's will work for me with the F23? Anyone used them for this app?
hnthomps
Total ratings: 50
Report this Post10-11-2014 08:33 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have not used Rodney's select cable in this specific application, but do have one on an 88 with a Getrag 282 and a modified 3800 SC Series III engine and it works well. I had Rodney double insulate the cable and it has been in use for several years without a problem. If the cables are the same length (and I assume they are knowing Rodney's thoroughness) I cannot see any reason why it would not work for your application.
Nelson
