  What order
What order by Lou6t4gto
Started on: 10-09-2014 07:14 PM
Replies: 3 (110 views)
Last post by: Lou6t4gto on 10-09-2014 07:40 PM
Lou6t4gto
Report this Post10-09-2014 07:14 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
What order do the Spring/sleeve/ pin go into the steering wheel for the Horn (under the horn button, GT Wheel)? Thanks
Ken_86gt
Report this Post10-09-2014 07:21 PM Click Here to See the Profile for Ken_86gtSend a Private Message to Ken_86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Horn spring into the hole
Put the pin into the sleeve with the flat side of pin at bottom
Push in the sleeve/pin assembly and give a a slight clockwise twist to lock it into the holder.
The flat side of the pin is against the spring and should rebound if pushed in.
[This message has been edited by Ken_86gt (edited 10-09-2014).]
Ken_86gt
Report this Post10-09-2014 07:24 PM Click Here to See the Profile for Ken_86gtSend a Private Message to Ken_86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ken_86gt
Member since Jan 2004
Lou6t4gto
Report this Post10-09-2014 07:40 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, been awhile since I removed the wheel to fix the wobble column.
