  Do the 97-2003 3800SC MAF sensors use the same flow curve as the 04-07 units?
Do the 97-2003 3800SC MAF sensors use the same flow curve as the 04-07 units? by Dennis LaGrua
Started on: 10-08-2014 10:36 PM
Replies: 3 (109 views)
Last post by: nosrac on 10-08-2014 11:06 PM
Report this Post10-08-2014 10:36 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3800SC engines until 2003 used a MAF sensor that was integral with the throttle body. On later DBW engines (IIRC 06-07) the MAF sensor used was a separate inline unit. I am involved in a swap now where I need to determine if the MAF curves on the integral and inline MAF sensors are 1. Similar, 2. Exactly the same 3. Completely different. The engine will use the 03 GTP PCM. Has anyone compared the MAF curves? Result?
Report this Post10-08-2014 10:58 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just downloaded an 03 and 05 program. We will have the answer shortly
nosrac
Total ratings: 50
Report this Post10-08-2014 11:02 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope!
nosrac
Total ratings: 50
Report this Post10-08-2014 11:06 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
Member since Jan 2005
Curious as 2 Y do you need the MAF curve? U using 2004+ Drive by Wire TB?
