  how high can the front of the car be and still get the rear cradle back in easy?
how high can the front of the car be and still get the rear cradle back in easy? by hookdonspeed
Started on: 10-08-2014 12:09 PM
Replies: 3 (308 views)
Last post by: hookdonspeed on 10-08-2014 02:40 PM
hookdonspeed
Total ratings: 131
Report this Post10-08-2014 12:09 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
like if the fronts on a set of ramps, will the back come down enough to put the rear cradle back in easy? or would the front need to be lowered again first?
Report this Post10-08-2014 01:17 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is this a hypothetical or are you out of jack stands?
With the front end up it'll take more lift under the front of the cradle me thinks.
Report this Post10-08-2014 01:28 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It really depends on how high the front of the cradle is as you slide it into position. With the cradle on the legs of the cherry picker, the front wheels need to be on the ground.
Unless you plan to raise the cradle into the chassis or your cradle dolly has the cradle 18" off the ground, you will likely find that the front wheels need to be on the ground.
hookdonspeed
Total ratings: 131
Report this Post10-08-2014 02:40 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
that's the info I was looking for. thankyou! its what I though, but just wanted to verify.
