  Oil Leak on 2.5L engine
Oil Leak on 2.5L engine by firstred84
Started on: 10-08-2014 07:33 AM
Replies: 5 (249 views)
Last post by: TopNotch on 10-09-2014 08:40 AM
firstred84
Report this Post10-08-2014 07:33 AM Click Here to See the Profile for firstred84Send a Private Message to firstred84Edit/Delete MessageReply w/QuoteDirect Link to This Post
This poor little car has had an oil leak for so long. It has finally progressed to a constant drip while running. Unfortunately in a pretty well hid area, but could be worse. It is leaking just to the right (passenger side) of the distributer. This is a 2.5L engine. It looks like it is leaking from an electrical plug. I'm guessing it is the oil pressure sensor. I was able to blindly remove the oil soaked plug. It is a three prong plug with what looks like a Brown/White wire and two other tan or brown wires. I don't see anything on the electrical diagrams that look like this. The oil pressure sensor is only shown as one wire on the diagram for some reason and goes to the fuel pump relay as it should. I need to get a mirror and light down there to look at things before I pull that sensor out. The sensor body does not seem loose, although I can rotation the 3 prong terminal part. Like I said before, I am working blindly. Could the sensor be leaking because the terminal rotates, or is there something else down there that I can not see. A manifold is currently blocking my view.
Thanks for any help! I'm looking forward to not polluting the world.
jaskispyder
Total ratings: 205
Report this Post10-08-2014 08:55 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oil pressure sender. Just replace it and see if that helps.
http://www.rockauto.com/cat...pk=929921&cc=1249006
(assuming it is an '84, based on your username)
[This message has been edited by jaskispyder (edited 10-08-2014).]
Report this Post10-08-2014 09:17 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
firstred84
Report this Post10-08-2014 09:39 AM Click Here to See the Profile for firstred84Send a Private Message to firstred84Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! Big help. Thanks for the pics. It is an 84. I'll let you know what happens.
firstred84
Report this Post10-09-2014 06:47 AM Click Here to See the Profile for firstred84Send a Private Message to firstred84Edit/Delete MessageReply w/QuoteDirect Link to This Post
Oil leak has been fixed. It turned out to be the oil pressure switch after all. Thanks to everyone for their feedback.
TopNotch
Total ratings: 60
Report this Post10-09-2014 08:40 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a leaking 88 sensor once. I guess any year can develop a leak.
