  Will a hydro booster work on our fieros?
Will a hydro booster work on our fieros? by Tweeder
Started on: 10-08-2014 12:11 AM
Replies: 14 (363 views)
Last post by: darkhorizon on 10-08-2014 03:08 PM
Tweeder
Report this Post10-08-2014 12:11 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the opportunity to trade a part for a hydroboost set up. If it will benefit my fiero then I may make the trade.
86 SE Convertible 3800sc 4t65e HD(2002), Gen V, 3.5 pulley, SD headers
Lou6t4gto
Report this Post10-08-2014 12:20 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
first, WHAT is a hydroboost ?
Ken_86gt
Report this Post10-08-2014 12:28 AM Click Here to See the Profile for Ken_86gtSend a Private Message to Ken_86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why add the complexity? The vacuum system works very well on cars. If you have to rebuild it it will cost much more than your existing system.
Tweeder
Report this Post10-08-2014 12:28 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a brake system that gets rid of the booster I place of a hydraulically actuated pump that is fed from the the power steering pump.
Mostly used on low to no vacuum braking situations.
[This message has been edited by Tweeder (edited 10-08-2014).]
Tweeder
Report this Post10-08-2014 12:32 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tweeder
Member since Aug 2012
Was just wondering if it's a better braking set up. I will hopefully this winter be upgrading the brakes.
sardonyx247
Total ratings: 219
Report this Post10-08-2014 01:19 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you see the problem here on a Fiero?
Tweeder
Report this Post10-08-2014 01:20 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope, I have the 3800
86 SE Convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
sardonyx247
Total ratings: 219
Report this Post10-08-2014 02:11 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
but do you want to hook up a power steering pump, run lines up to the front, add weight to the car, add problems that are costly to fix, just for the same braking power?
Tweeder
Report this Post10-08-2014 02:15 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
That in a nut she'll is what I'm wondering, if all that's worth what ever gains in braking. There's more to it than I initially thought, seems to me the answer is no.
sleevePAPA
Report this Post10-08-2014 02:16 AM Click Here to See the Profile for sleevePAPASend a Private Message to sleevePAPAEdit/Delete MessageReply w/QuoteDirect Link to This Post
Waste of time unless you are trying to build a lot of boost on the brakes.
lateFormula
Report this Post10-08-2014 07:03 AM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or on many Ford vehicles in the 80's and 90's.
TK
Total ratings: 200
Report this Post10-08-2014 09:13 AM Click Here to See the Profile for TKSend a Private Message to TKEdit/Delete MessageReply w/QuoteDirect Link to This Post
And lots of GM turbo applications and especially the turbo diesel engines like the Duramax.
I see no upside in using hydroboost unless you have a boosted or low vacuum engine and can't get enough vacuum to run the brakes. Otherwise it's a fix for a problem that doesn't exist.
[This message has been edited by TK (edited 10-08-2014).]
Zac88GT
Report this Post10-08-2014 10:23 AM Click Here to See the Profile for Zac88GTClick Here to visit Zac88GT's HomePageSend a Private Message to Zac88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
One advantage to the hydroboost is the ability to have consistent multiple brake applications while still under throttle (if your an autocrossing left foot braker).
Report this Post10-08-2014 11:48 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many cars w/o turbo etc uses this.
hydro booster is small and designers can use boost pressure as part of ABS system, auto braking, etc.
Some new cars does, or will use in near future, electronic brake boost for above reasons and more.
Converting Fiero vacuum boost to use either?
Even if you can, likely a bad plan. Anything goes wrong could cause big problem. If brake boost fails many won't be able to stop in even 2x normal stopping distance.
Note that Vac boost can fail w/o being totally dead. Common issues are Leaking or block vacuum line/filter, one of two diaphragms is dead, control valve problem, vac check valve bad or full of crap.
darkhorizon
Total ratings: 451
Report this Post10-08-2014 03:08 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know some of the blazer guys have done this, and results were mediocre at best.
