  ZZ Powerlogs on a 3800SC
ZZ Powerlogs on a 3800SC by Dennis LaGrua
Started on: 10-06-2014 07:26 PM
Replies: 4 (550 views)
Last post by: Dennis LaGrua on 10-07-2014 10:24 PM
Report this Post10-06-2014 07:26 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone else running ZZ Powerlogs? I have the stainless steel type but it sat so close to the A/C Compressor that I took them off. This manifold is non-restrictive, flows well but when installed it sits only 1/8" away from the A/C compressor. This has got to have a negative effect and decreased life on the A/C system . I believe that I will need to modify the P-Log for greater A/C Compressor clearance but still looking for expert and other opinions on this.
fieroaddicted
Report this Post10-06-2014 07:46 PM Click Here to See the Profile for fieroaddictedSend a Private Message to fieroaddictedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know when I installed my mustang header, it would hit on the starter. I had to modify it quite a bit in order to get it to where i could use it. Still it ended up that i have about a 1/4" of gap. I wrapped it in header wrap, but I have not driven it yet so I am not sure of how it will hold up. I am hoping the wrap makes the difference. Just a thought, not sure if ya are for/against that idea, but figured i would throw my 2 cents in.
troy
Report this Post10-07-2014 02:43 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
troy
I am not fond of wrapping headers as they have a tendency to crack. I would wrap the starter in a heat shield. In the case of the Powerlog there isn't even enough clearance to wrap the compressor as the heat shield wrap would sit almost right on the exhaust. I can probably free up some clearance by compressing the pipe with a couple of large C clamps and a piece of steel.
Report this Post10-07-2014 04:11 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
1/8" is plenty of room to tack weld a thin piece of sheet metal for a heat shield between the header pipe and the A/C compressor. As long as there is a small air gap, the heat shield will stop the largest % of the radiant heat from from the exhaust pipe going to the A/C compressor. You could also slot the mounting holes for the A/C compressor to lower it another 1/16" to 1/8".
Report this Post10-07-2014 10:24 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess that we could take that approach but I'd feel a whole lot more comfortable if we could get that air gap to a minimum of 1/4" without disturbing compressor mounting. We are talking about altering only 1/8" of material of the powerlog only a few inches in length. I believe that I can do this neatly with a auto body tool ( anvil dolly) tapping along the highest point of a section of the manifold tube radius where it sits under cylinder #1 and over the A/C compressor. I believe that its possible to make this look neat and do the alteration without decreasing flow. If only ZZ made these powerlogs with 1/4" of clearance over the A/C compressor we would not be having this discussion.
