  What starter for 350/th125
What starter for 350/th125 by skidd1000
Started on: 10-03-2014 09:35 AM
Replies: 4 (526 views)
Last post by: skidd1000 on 10-04-2014 09:43 AM
skidd1000
Report this Post10-03-2014 09:35 AM Click Here to See the Profile for skidd1000Send a Private Message to skidd1000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know what starter will work with a 350 chevy and the 125 auto? I have the trans adapter,the flex plate adapter and mounts. The flex plate is a 42 tooth. I bought a new cradle and another 125 to overhaul, and want to mock everything up before I pull the drive train out of the car.
Lou6t4gto
Report this Post10-03-2014 02:25 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
WHY are you using a 125 ? it'll never "Last" and will be terrible on gas. You would better to just use a 4t60, or 4t65 to begin with.
WICKEDWILDFIERO
Report this Post10-03-2014 09:30 PM Click Here to See the Profile for WICKEDWILDFIEROSend a Private Message to WICKEDWILDFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
FieroGT42
Total ratings: 67
Report this Post10-03-2014 10:41 PM Click Here to See the Profile for FieroGT42Send a Private Message to FieroGT42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Will the Grand Prix starter not swap in with that block?
skidd1000
Report this Post10-04-2014 09:43 AM Click Here to See the Profile for skidd1000Send a Private Message to skidd1000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks wicked! I believe that is exactly what I am looking for. Too bad they are over $200. Fierogt, The starter gets relocated to the other side of the 350 block and mounts to the trans adapter sideways so a oe style starter will not work. As far as my choice to use the 125 trans, It's simple, I have one, actually 2 of them. No need to change drive shafts and if you do your research you will see people have put 500+ hp to these with no problems. I have a Ferrari F355 body kit on this car and it will not be a daily driver. Parades,car shows,and an occasional car club cruse will be all this sees. But thanks for your concern lou6. Search my user name and I think there is a picture of it in primer. Thanks guys. Steve.
