  88 duke V5 ac compressor pressure switch questions
88 duke V5 ac compressor pressure switch questions by dalark68
Started on: 09-29-2014 10:12 PM
Replies: 2 (140 views)
Last post by: dalark68 on 09-30-2014 12:48 PM
dalark68
Report this Post09-29-2014 10:12 PM Click Here to See the Profile for dalark68Send a Private Message to dalark68Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey forum, been reading how to for years and can't thank this community enough for the vast knowledge I have been presented.
Anyways, I recently pulled my duke out to do some frame work and figured while it's out , I would change the original AC compressor. I ordered a replacement 4 seasons rebuilt compressor and realized once I got it, it had only one hole for a pressure switch on back where my original has 2 pressure switches ( red and green ). Both compressors are identical ( same part number ) other than the rebuilt one having a hole for only one pressure switch. Is there a way to make this work?
[This message has been edited by dalark68 (edited 09-29-2014).]
Report this Post09-30-2014 02:38 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ask 4 seasons.
The port you have could be for high pressure cut out, low pressure cut off, etc.
Could be right # but wrong part in the box.
V5 need correct control "valve" too. Likely you have R12 valve. R134 can work but wrong valve hurts performance.
dalark68
Report this Post09-30-2014 12:48 PM Click Here to See the Profile for dalark68Send a Private Message to dalark68Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Ogre, will call them up to figure this out. BTW, great write-up in the cave about the Duke timing gear replacement. Worked just like you said. Saved a whole bunch of time instead of pulling out cam and pressing it on. Thx
