  car wont start
car wont start by cowboy39
Started on: 09-28-2014 11:48 AM
Replies: 8 (318 views)
Last post by: cowboy39 on 09-28-2014 09:50 PM
cowboy39
Report this Post09-28-2014 11:48 AM Click Here to See the Profile for cowboy39Send a Private Message to cowboy39Edit/Delete MessageReply w/QuoteDirect Link to This Post
i was driving my 86 se about 2 weeks ago and it just died and wont start when i turn the key it cranks over i sprayed starting fluid in throttle body but didn't help any
LorenBateman
Report this Post09-28-2014 12:25 PM Click Here to See the Profile for LorenBatemanSend a Private Message to LorenBatemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
are you getting fire from the plugs
Total ratings: 290
Report this Post09-28-2014 12:31 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you turn the key to the start position does the tach show about 200 RPMs and after you release it does the tach drop back to zero?
If not suspect in this order
ICM
Pick up coil
Ignition to ICM harness - http://www.reddevilriver.com/2.html
Ignition coil.
If your ICM is bad use thermal paste under it when replacing it.
If your ICM is bad and your ignition coil and/or plug wires are old replace them. High resistance in the plug wires break down the insulation in the ignition coil. Broken down insulation in the ignition coil fries the ICM and causes ICM failures.
If your ICM is bad and your spark plugs are old replace them. All 6, not just the back 3
Alex.07.86GT
Report this Post09-28-2014 01:36 PM Click Here to See the Profile for Alex.07.86GTSend a Private Message to Alex.07.86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
pull out coil wire from coil and crank it. see if coil arks to wire about 1/2inch away. youll need a helper. keep starter fluid far far away!
pull out some plugs and let us know if they are wet with gas or oil or dry, etc
Good Luck!!
[This message has been edited by Alex.07.86GT (edited 09-28-2014).]
cowboy39
Report this Post09-28-2014 03:12 PM Click Here to See the Profile for cowboy39Send a Private Message to cowboy39Edit/Delete MessageReply w/QuoteDirect Link to This Post
ok just got home turned it over the tach stays on zero got a spark from the coil but no spark coming from the plug wire
[This message has been edited by cowboy39 (edited 09-28-2014).]
Alex.07.86GT
Report this Post09-28-2014 04:59 PM Click Here to See the Profile for Alex.07.86GTSend a Private Message to Alex.07.86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
coil delivers spark to cap via coil wire, cap to rotor to cylinder wires.
if its all connected and you have no spark at the 6 wires -its either a bad coil wire or a bad cap & rotor.
does the distributor turn when cranking?
"tach stays on zero" thats usualy a bad ICM.
cowboy39
Report this Post09-28-2014 05:23 PM Click Here to See the Profile for cowboy39Send a Private Message to cowboy39Edit/Delete MessageReply w/QuoteDirect Link to This Post
the Distributor turns but i was looking and the pins inside the Distributor cap that the rotary button hits have some deep grooves wore on them
Total ratings: 290
Report this Post09-28-2014 08:05 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
post a pic
cowboy39
Report this Post09-28-2014 09:50 PM Click Here to See the Profile for cowboy39Send a Private Message to cowboy39Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know how never posted a pic before
