  Fuel Line O Ring 1984 Stock Iron Duke
Fuel Line O Ring 1984 Stock Iron Duke by jakejoseph
Started on: 09-27-2014 05:50 PM
Replies: 4 (745 views)
Last post by: KurtAKX on 09-29-2014 01:27 PM
jakejoseph
Report this Post09-27-2014 05:50 PM Click Here to See the Profile for jakejosephSend a Private Message to jakejosephEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just finished installing a new fuel pump in my 84 stocker - it had just been done previous to my purchasing the car, but whoever installed the new fuel pump did not use submergable lines...pretty amazing what happens to non submergeable lines when in the tank....
Any case, I hooked everything back up, and the line coming out of the fuel filter leaks. Is there supposed to be O-rings on both sides of the fuel filter or just on the exit side? Or at all?
J
Report this Post09-27-2014 10:15 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel filter uses 2 fuel proof O-rings. GM are orange colored. Many black ones won't last long.
84fiero123
Total ratings: 325
Report this Post09-29-2014 10:19 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Both sides require the o ring, its just the way they are made. if I am not mistaken and I have been before you can get GM o rings at the dealer still, just the o rings for under a buck or so. They will last longer, better material.
Steve
KurtAKX
Total ratings: 128
Report this Post09-29-2014 01:24 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
you might look at Dorman 800-013, available at your local auto parts store.
KurtAKX
Total ratings: 128
Report this Post09-29-2014 01:27 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
KurtAKX
Member since Feb 2002
OR
Fuel feed:
GM 22514722 / ACDelco 217-452
Fuel return:
GM 22516256
