  Cleaning Carpet Drenched in Brake Fluid
Cleaning Carpet Drenched in Brake Fluid by Notorio
Started on: 09-26-2014 08:52 PM
Replies: 8 (767 views)
Last post by: Notorio on 09-28-2014 09:20 PM
Notorio
Report this Post09-26-2014 08:52 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
My new GT 5spd with the classic 'won't shift' problem arrived with the trunk saturated in what looked and smelled like brake fluid. I figured that a prior owner had a bottle open & spill there so I just soaked it up with rags as a temporary measure. Moving on to rebuilding the clutch slave cylinder with Rodney's excellent kit and bleeding tool, I pumped through quite a bit of new fluid (often topping up the master cylinder) but couldn't build up any pressure when the original bleeder screw was tightened closed. I started to wonder where all the fluid was going and then remembered Posts about leaking master cylinders ... you guessed it, the missing fluid was busy drenching the carpet and insulation under the dash .
Now that I have Two carpet areas to clean up I thought I would check with the forum to see if there are any tried-and-true methods out there. Any recommendations? I was thinking of soaking up the excess and renting a steam cleaner.
John
James Bond 007
Total ratings: 263
Report this Post09-26-2014 09:14 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Probubley never get the smell out. Have you considered insalling new carpet? I baught mine from a Fiero parts dealer, Im not complaning,but its rather thin for the money.I can't remember what I paid $80 to $110 Plus shipping. Home Depo once sold simular carpet, (use your old carpet as a template).Thin carpet is much easyer to work with than thick carpet.Your probubley going to need the backing too.Keep in mind, its not a good idea to be breathing those fumes.
Ponnari
Report this Post09-26-2014 09:46 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thought it was only me that stuff happened to,
I cleaned one of mine by taking the carpet section out and taking it to the self car was. Rinsed it then soaked it with simple green top & bottom. Let it soak about ten minutes, then rinsed it front & back again. Then when I got home, cleaned it with a Bisel carpet cleaniner using the furniture attachment. It came out really well and now has a slight smell of Simple Green, which really isn't bad IMO. The brake fluid did deteriorate the rubber on the bottom of the carpet a little bit , so try at your own risk.
Good Luck!
Total ratings: 463
Report this Post09-27-2014 01:58 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use a product called Mean Green, from Dollar General.
It's kind of like Simple Green, only nastier. (It will oxidize bare aluminum.)
It's a superb degreaser. I cleaned an oil stained trunk carpet with the stuff (alternating with Tide) and it got everything out except for a little bit of rust.
It's quite concentrated. You'll have to flush it with a hose and nozzle repeatedly to get it all washed out.
Praise the Lowered!
Notorio
Report this Post09-27-2014 03:58 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good point about the 'fumes' and long-term exposure. With any of these cleaning approaches looks like I will be taking out the carpet after all ... is it one giant piece or does the drivers side come out on its own? Never took one out before. Is that underlayment/insulation 'special' or could I replace it with home-store carpet padding?
Marvin McInnis
Total ratings: 227
Report this Post09-28-2014 01:16 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
FWIW ... DOT 3 & 4 brake fluids are generally water soluble glycols and glycol ethers. A mild detergent and water should work as well as anything.
[This message has been edited by Marvin McInnis (edited 09-29-2014).]
Mickey_Moose
Total ratings: 145
Report this Post09-28-2014 09:01 AM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Marvin McInnis:
FWIW ... DOT 3 & 4 brake fluids are generally water soluble glycols and glycol ethers. A mild detergent and water should do a pretty good job.
This and a pressure washer works well for cleaning the carpets (out of the car of course) - takes a bit to dry though, but I just hung them over some railing on a nice sunny day.
Total ratings: 463
Report this Post09-28-2014 12:58 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't get too close with the pressure washer. I blew the stain off my deck with a low power one.
I just used a pressure nozzle on the garden hose.
The carpets are in two halves. Left and right.
84-87 had jute padding under the carpet. 88s had a fairly thick rubber backing molded in.
Notorio
Report this Post09-28-2014 09:20 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will have some time tomorrow/Monday to give your cleaning suggestions a try, and am relieved to hear the carpet is in two pieces (can't really open the passenger door where the car is right now.) Hopefully Rodney's new brake Master Cylinder will arrive the same day and perhaps I will finally get a chance to try the car out.
