  AC relay failure
AC relay failure by donuteater306
Started on: 09-22-2014 11:50 PM
Replies: 4 (249 views)
Last post by: phonedawgz on 09-23-2014 08:18 PM
donuteater306
Report this Post09-22-2014 11:50 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Other than the country where the relay is made Could there be another reason why two AC relays have failed on my car in 5 years? Same scenario both times. Turn on AC, compressor doesn't engage. hit a few bumps in the road and CLICK, it's on. Last time it happened, I replaced both the AC and fuel pump relays thinking that since they were both orig., I wanted to prevent a potential no-start. But here I am again. Turn on AC and occasionally have to tap the relay.
Total ratings: 290
Report this Post09-23-2014 01:16 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The diode on the compressor connector is bad.
It keeps the relay contacts from pitting.
http://www.progeny.co.uk/Back-EMF-Suppression.aspx
donuteater306
Report this Post09-23-2014 11:01 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Woah, thank you..I had no idea! That's actually an interesting article. So now the question is, do I just go to RadioShack for a diode and splice it in, or does Delco still sell the pigtail?
donuteater306
Report this Post09-23-2014 11:05 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
donuteater306
Member since Feb 2010
Whup, found it. Delco part# PT179 connector W/diode.
Total ratings: 290
Report this Post09-23-2014 08:18 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Radio Shack sells diodes also.
http://www.radioshack.com/p...sp?productId=2036270
If you do use the Radio Shack diode make sure the band on the diode connects to the Dk. Green wire. The end of the diode without the band connects to the Black wire.
[This message has been edited by phonedawgz (edited 09-23-2014).]
