Front upper CA?
More likely, the bolt, nut, washers, and/or bushings are loose/bad.
If tube is bad now too... get another front cross-member.
Edit to add> If you have Polyurethane bushing... Poly bushing inner sleeve will start to move before OE rubber. Poly sleeve has no teeth to prevent that and if the bolt is under torque even a little the parts can wear sooner then OE types..
(Jurassic Park)The Ogre's Fiero Cave (It's also at the top and bottom of every forum page...)
[This message has been edited by theogre (edited 09-20-2014).]
