  Mystery Pipe
Mystery Pipe by shurlbert
Started on: 09-19-2014 07:59 PM
Replies: 6 (205 views)
Last post by: Patrick on 09-19-2014 09:28 PM
shurlbert
Report this Post09-19-2014 07:59 PM Click Here to See the Profile for shurlbertSend a Private Message to shurlbertEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone,
I am reinstalling my plenum after eliminating the cold start injector and I have a pipe that I can't figure out where it goes. It is about half inch in diameter and is aimed toward the air cleaner (assuming that is where it is supposed to be aimed). It is located right above the cold start injector. It is hard plastic and is connected to the engine with a rubber sleeve. It rotates freely, so I guess it is a vacuum line
Does anyone know what this is for and where it is supposed to hook up to? I have a picture, but I don't know how to upload it here.
Thank you.
David Hambleton
Report this Post09-19-2014 08:14 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try clicking the Pennocks Image Poster icon at the bottom of the screen to upload pictures.
Report this Post09-19-2014 08:27 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Goes to the back of the throttle-body.
shurlbert
Report this Post09-19-2014 08:31 PM Click Here to See the Profile for shurlbertSend a Private Message to shurlbertEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tried the image poster, but it won't resize the image to a manageable size
FieroJosh1993
Report this Post09-19-2014 08:34 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
it goes from the middle plenum to the bottom of the throttle body.
shurlbert
Report this Post09-19-2014 08:51 PM Click Here to See the Profile for shurlbertSend a Private Message to shurlbertEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Patrick,
Yep, that was it. I couldn't see the opening on the throtle body.
Again, Thank you
Report this Post09-19-2014 09:28 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
PIP is the best way to post images here, as they won't disappear down the road. However, re-sizing images that are too large needs to be done separately. I use IrfanView myself, but many other free apps are available.
Thanks Patrick...
You're welcome.
