  Rough idle after warm up 88 Duke
Rough idle after warm up 88 Duke by un fiero
Started on: 09-16-2014 09:34 PM
Replies: 5 (189 views)
Last post by: phonedawgz on 09-22-2014 01:10 PM
un fiero
Report this Post09-16-2014 09:34 PM Click Here to See the Profile for un fieroSend a Private Message to un fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 88 base coupe 2.5 duke is running great (mostly), but 50% of the time it idles low after warm up. I did a head gasket a couple months ago as well as injector o-ring, thermostat, intake temp sensor, egr valve and numerous vac hoses both coolant temp sensors and the ICM. It starts and runs great except for when it starts this idle dipping. It doesn't stall but feels like it wants to. Any suggestions? Thanks!
Report this Post09-17-2014 09:09 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Whats the history, why did you replace all these things, had it been sitting for years or something?
Dukeiboy
Report this Post09-17-2014 11:30 PM Click Here to See the Profile for DukeiboySend a Private Message to DukeiboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is your car automatic or standard?
Red '84, 75,000 miles.. work in progress
un fiero
Report this Post09-18-2014 05:43 PM Click Here to See the Profile for un fieroSend a Private Message to un fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its an automatic. The car was running and driving when I got it but head gasket was slowly seeping. I do believe it probably set up some, but it has always run pretty good till recently when it started this.
Report this Post09-22-2014 12:43 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 290
Report this Post09-22-2014 01:10 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The IAC motor rarely goes bad, and if it did that would cause the IAC to stick in one position. An up and down idle isn't going to be caused by an IAC.
A leaking EGR valve is the first place to look at for a rough idle.
