  Oil leak though the "keyhole" of the balancer.. How do you stop it?
Oil leak though the "keyhole" of the balancer.. How do you stop it? by unboundmo
Started on: 09-16-2014 02:35 PM
Replies: 5 (231 views)
Last post by: fierosound on 09-17-2014 08:50 AM
unboundmo
Report this Post09-16-2014 02:35 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found this post just recently... Well, I have the same problem.. The leak comes from the center of the balancer.. I have even sleeved my balancer just in case.... But it's the keyhole... How does one fix this?
Originally posted by Snapperhead:
I found the crazy oil leak that has been giving me a hard time to find>
Leaking right out of the keyway in the balancer.. I will fix it this week and hopefully stop the oil leak for good. This makes one heck of a mess.
Vince
tom10122
Report this Post09-16-2014 02:58 PM Click Here to See the Profile for tom10122Send a Private Message to tom10122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Link to the thread we can't see the pic
Report this Post09-16-2014 03:17 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can see the pic just fine.
Pull the balancer and apply a thin film of sealant to the bore as well as key way. Remove the key, apply some sealant to the key and key way, re-install the key, re-install the balancer, apply some sealant to the bolt, and torque properly.
[This message has been edited by fieroguru (edited 09-16-2014).]
unboundmo
Report this Post09-16-2014 04:22 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guru.. Now that I have the engine back out it'll be easier to fix too
Fierobsessed
Total ratings: 147
Report this Post09-17-2014 02:00 AM Click Here to See the Profile for FierobsessedSend a Private Message to FierobsessedEdit/Delete MessageReply w/QuoteDirect Link to This Post
What guru said.
It's actually a standard assembly procedure for most GM engines. You're supposed to put sealant on the key and keyway to prevent leaking.
fierosound
Total ratings: 286
Report this Post09-17-2014 08:50 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup. Experienced the same problem, and "proper assembly" is what fixed it.
Calgary time/temp
