  TunerPro
TunerPro by bonaduce
Started on: 09-16-2014 02:14 PM
Replies: 4 (448 views)
Last post by: bonaduce on 09-16-2014 08:42 PM
bonaduce
Report this Post09-16-2014 02:14 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I downloaded Tunerpro so that I can have access to live data streaming without borrowing the shop scan tool stuff. I am thinking since I have 3.4DOHC swap that this is the xdf file yhat I need to download to use with the program. When I scan throught the files, I see that there are three files in that row, 2 xdf, and one definition, do I need all?
thanks for any info
Dan
Total ratings: 290
Report this Post09-16-2014 02:25 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The ONLY file you need to scan is the .adx file.
Download my install disk and all the latest definitions are located in the TunerPro RT USB Direct ADX Definitions directory
https://dl.dropbox.com/u/22...River%20USB-ALDL.zip
Two definitions to chose from:
1991 - 93 3.4 (LQ1) DOHC & 3.1L (LH0) V6, W Body Chevy Buick Pontiac $DF-16149396-V1.adx
1994 - 95 3.4 (LQ1) DOHC 16196401 -- $2E.adx
[This message has been edited by phonedawgz (edited 09-16-2014).]
bonaduce
Report this Post09-16-2014 04:41 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks phonedawgs, does that install file come with your cable, as I need to order that also
dan
[This message has been edited by bonaduce (edited 09-16-2014).]
Total ratings: 290
Report this Post09-16-2014 05:33 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes with the cable is included the disk, which is the same as what you can download with the above link.
Here is the ALDL cable itself. For anything 93 and earlier the 12 pin version is what you are looking for. 94-95 might be 12 or 16, you have to look at your connector.
http://reddevilriver.com/aldl.html
bonaduce
Report this Post09-16-2014 08:42 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks again
dan
