  no power to starter or yellow wire
no power to starter or yellow wire by fieroguy75
Started on: 09-14-2014 12:01 PM
Replies: 10 (362 views)
Last post by: petehiggins75 on 09-14-2014 02:51 PM
fieroguy75
Report this Post09-14-2014 12:01 PM Click Here to See the Profile for fieroguy75Click Here to visit fieroguy75's HomePageSend a Private Message to fieroguy75Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had a red wire catch on fire when I turned the key on,the first time it just smoked,a fire the next time I turned it over.i replaced the starter,fuse link but nothing.i have juice to the pink and purple wires.grounds and connections look fine.red wire goes into the car.i suspect that the switch may be bad so I just bypassed it.and ideas are greatly appreciated.my email is petehiggins75@gmail.com
thank you,frustrated in Waynesboro car is an 86 duke w/auto
peter higgins
[This message has been edited by fieroguy75 (edited 09-14-2014).]
Alex.07.86GT
Report this Post09-14-2014 12:13 PM Click Here to See the Profile for Alex.07.86GTSend a Private Message to Alex.07.86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
fuse-able links should prevent all smoke & fire!
replace the wires in question and try to install fuse that can be removed easily ___after you troubleshoot why the engine isnt turning - if thats the case here.
*and rather than just change the starter you should have bench tested it to see if that was really the problem.
[This message has been edited by Alex.07.86GT (edited 09-14-2014).]
petehiggins75
Report this Post09-14-2014 12:34 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
Car does run but had to bypass the starter.I took the old starter to advance auto. They tested it and it was fried.
Alex.07.86GT
Report this Post09-14-2014 12:55 PM Click Here to See the Profile for Alex.07.86GTSend a Private Message to Alex.07.86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im not sure exactly what wires were smoking/ fire/damaged, but you need to replace them and use replaceable fuses or fuseible links.
I think 1 wire goes to the alternator and the other to the fuse panel. then of course the battery cable.
if the fusible links burnt up you could cut them out and connect as a test. then replace if they look/test bad.
petehiggins75
Report this Post09-14-2014 01:06 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK
Thanks for the input.I'll check it out
Total ratings: 290
Report this Post09-14-2014 01:29 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
How does one start the car by bypassing the starter?
The Yellow wire runs directly from C500 to the ignition switch located on the column under the dash (NOT IN THE STEERING COLUMN) If everything else is working except power to the starter I am thinking that the switch is the most likely suspect. Unplug the switch and with a wire as large as the yellow wire try jumpering between the yellow wire and the red wire of the ignition switch plug.
Under the dash - not in the column - click the IMG below
Not an actual Fiero ignition switch but shown to give you the idea.
[This message has been edited by phonedawgz (edited 09-14-2014).]
petehiggins75
Report this Post09-14-2014 01:39 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
Simply ran a second 10 guage wire off the solenoid from the hot side.and I appreciate the input,will go look right now....thanks
petehiggins75
Report this Post09-14-2014 02:38 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
petehiggins75
Member since Jul 2014
No go.I jumped the red and yellow. There is some kind of relay below.it has a solid yellow, yellow n black and a ground.also now power to the pink in the blue block as well
petehiggins75
Report this Post09-14-2014 02:42 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
petehiggins75
I think initially what happened was a wire had a bare spot burned off and arced when I hit the key
petehiggins75
Report this Post09-14-2014 02:43 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
petehiggins75
My trunk release also not working
petehiggins75
Report this Post09-14-2014 02:51 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
petehiggins75
