  Bump-steer kit and the parking brake cable clearance
Bump-steer kit and the parking brake cable clearance by FieroVin
Started on: 09-13-2014 01:57 PM
Replies: 3 (216 views)
Last post by: lou_dias on 07-09-2019 08:22 AM
FieroVin
Report this Post09-13-2014 01:57 PM Click Here to See the Profile for FieroVinClick Here to visit FieroVin's HomePageSend a Private Message to FieroVinEdit/Delete MessageReply w/QuoteDirect Link to This Post
A question to the Fiero guru's out there. I just installed the Held/Arraut/Fierostore bump-steer correction kit on my 87 GT. It seems there is not enough clearance between the A-arm and the outer CV boot on the RH/passenger side and the boot is rubbing on the cable. I think I have the cable run the only way it could, which is on top of the A-arm. Does anyone have any experience with this, or a little advice on what to do? TIA
Vin
1987 Fiero GT, Medium Red Mettalic, Lowered
2008 Solstice GXP, Aggressive
2008 G8 GT, Magnetic Grey Mettalic
1988 - 2006 - The 18 year dry spell between 2-seat Pontiac Excitement was finally over... RIP Pontiac.
heavyhorse
Report this Post07-03-2019 06:22 PM Click Here to See the Profile for heavyhorseSend a Private Message to heavyhorseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you ever get this resolved? I have the same issue now that I replaced, my right axle.
Total ratings: 205
Report this Post07-03-2019 08:19 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry you wasted your time and money on the bumpsteer kit.
Hope you check it often, wouldn't want something to break and cause a crash....
lou_dias
Total ratings: 67
Report this Post07-09-2019 08:22 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie installed mine so I don't know if he re-routed anything.
I did have to shave down the nut that's going vertical because when the axle nut was tightened, it would rub the outer shell of the CV and lock my axles up.
Edit:
//www.fiero.nl/forum/A...-2-072050-2.html#p50
Actually he didn't like the E-brake setup at all and never installed it.
[This message has been edited by lou_dias (edited 07-09-2019).]
