  3800/F40 Flywheel Question
3800/F40 Flywheel Question by Fiero Vampire
Started on: 09-12-2014 03:34 PM
Replies: 1 (198 views)
Last post by: mkman on 09-12-2014 04:43 PM
Fiero Vampire
Report this Post09-12-2014 03:34 PM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
I looked and searched and really haven't found the answers I'm looking for, hopefully someone can answer the following questions.
1. Has any one used the SC82A Spec Aluminum flywheel on their 3800/F40 build?
2. If so what is your opinion on how it drives/performs?
3. If I buy the SC82A Spec Aluminum flywheel and the SPEC SC883F-4 Stage 3+ Clutch kit, will I need anything else besides flywheel bolts (Part#?) and .25 inch HTOB spacer?
4. Also where can I get a HTOB Spacer or does this come from SPEC when I order the flywheel and clutch?
Question #2 is properly the most important.
mkman
Report this Post09-12-2014 04:43 PM Click Here to See the Profile for mkmanSend a Private Message to mkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The throw out bearing spacer comes with the clutch/pressure plate kit. I did not get the aluminum flywheel, so can't help you there. I purchased a steel flywheel balanced for the 3800 from member fierorog. Flywheel bolts if I remember correctly are 5/16 grade 8 bolts. I can't comment on the clutch yet because my build is not finished.
