  Delco TPS
Delco TPS by donuteater306
Started on: 09-10-2014 01:59 AM
Replies: 3 (182 views)
Last post by: fierofool on 09-10-2014 07:03 PM
donuteater306
Report this Post09-10-2014 01:59 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a new Delco TPS for my 87 GT. Sensor came with new screws and these little metal tabs with a hole that looks like a screw goes threw. I wish I could post a photo. What are these metal tabs for? I'm assuming that they either go between the throttle body and sensor, or sensor and screw.
sardonyx247
Total ratings: 219
Report this Post09-10-2014 02:19 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
sensor and the screw
edit to add:
it looks completly pointless, I still can't figure out why or what it is there for, but I have seen lots of them.
Your name....are you a cop?
[This message has been edited by sardonyx247 (edited 09-10-2014).]
donuteater306
Report this Post09-10-2014 02:41 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ah ok thanks. I guess simple round washers were too easy. haha
[This message has been edited by donuteater306 (edited 09-10-2014).]
Report this Post09-10-2014 07:03 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, the original had a crescent shaped metal bracket that the screws went through. Probably to help spread the load so the TPS didn't get broken when tightening. The TPS should sit flush against the throttle body. BTW, put a little never-seize on the threads. The aluminum bolts are prone to seize and/or break and/or heads strip out and/or any combination and/or all of the preceding.
