  need help with 4t60 / sbc swap
need help with 4t60 / sbc swap by TM
Started on: 09-08-2014 09:01 PM
Replies: 1 (231 views)
Last post by: FFIEROFRED on 09-09-2014 08:33 PM
TM
Report this Post09-08-2014 09:01 PM Click Here to See the Profile for TMSend a Private Message to TMEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone done this exact swap? I am at the stage of needing the axles for this application.
Does anyone have the part numbers or have them for sale? If they have to be custom made, can you direct me to the who has done them in the past?
Thank you in advance for your help.
FFIEROFRED
Report this Post09-09-2014 08:33 PM Click Here to See the Profile for FFIEROFREDSend a Private Message to FFIEROFREDEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had archie make me a drivers side axle. It had to be very short. the pass side was made with parts from 3 axles. Both sides use the tripots from the trans you are using. both sides use the outer "CV" joint from a mantrans fiero. the pass side AXLE is from a 1987 up to about 94 olds 98 / 88 or a park ave pass side axle.
