  89 a/t 4spd axle source?
89 a/t 4spd axle source? by AL87
Started on: 09-06-2014 11:35 AM
Replies: 13 (366 views)
Last post by: jimbolaya on 10-11-2014 08:32 PM
AL87
Report this Post09-06-2014 11:35 AM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a friend swapping in an auto 4spd and he's wondering if there is a source for a premade axle to fit the fiero.
the trans came out of a Cadillac, and he has the axles that came with it, along with the original fiero axles from his 125.
he doesn't want to cut/weld anything, IF there is no source for something premade, hes okay with mixing/matching parts from different axles to get this baby installed. we just need info to get started.
any and all info would be appreciated!
fierosound
Total ratings: 286
Report this Post09-06-2014 12:10 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the 440T4/4T60 4-speed automatic?
http://web.archive.org/web/...s.com/tech/440-4T60/
Axle assemblies for a 1989 Pontiac 6000 (with 2.8 V6, 4T60 and light duty brakes w/o ABS) fit out-of-the-box.
Part numbers
A1 CARDONE PN 601078 - LEFT side drive axle (21-inches long overall)
A1 CARDONE PN 601115 - RIGHT side drive axle (26.25-inches long overall)
Calgary time/temp
[This message has been edited by fierosound (edited 09-06-2014).]
AL87
Report this Post09-08-2014 01:30 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
double post*
[This message has been edited by AL87 (edited 09-08-2014).]
AL87
Report this Post09-08-2014 01:32 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
AL87
Member since Mar 2010
Part numbers
yes, that transmission!
looks sweet! Thanks!
Grantman
Report this Post09-08-2014 01:54 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
your friend will love that swap. those axles are plug and play.
AL87
Report this Post10-08-2014 09:33 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
I want to do that swap as well. because of the advantage the 4th gear has. more fuel economy!
BUT I'm lazy and don't want to fab the mounts up...
I'll let him know! thanks!
[This message has been edited by AL87 (edited 10-08-2014).]
lou_dias
Report this Post10-09-2014 12:29 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just bought an 86SE with a 3400 conversion done. I was told the transmission was the 4T60 but it doesn't shift into 4th. How can I identify which auto I am running?
I typically never buy autos so forgive my ignorance.
fierosound
Total ratings: 286
Report this Post10-09-2014 02:00 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
How can I identify which auto I am running? I typically never buy autos so forgive my ignorance.
I think it's stamped into the bottom oil pan. Have a look underneath.
Not shifting into 4th may simply be because the shifter mechanism or cable is not giving proper movement at the trans end (one gear off?)
Calgary time/temp
lou_dias
Report this Post10-10-2014 09:37 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, I'll try to get it up on my ramps this weekend.
Knight
Report this Post10-10-2014 02:14 PM Click Here to See the Profile for KnightSend a Private Message to KnightEdit/Delete MessageReply w/QuoteDirect Link to This Post
What mounts need to be fabed and to what degree?
jimbolaya
Total ratings: 114
Report this Post10-10-2014 06:43 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am doing this swap, but haven't gotten to mounts yet, but I have been told I use the fiero mounts and only have to drill new mount holes in the cradle. I will report when I find out, or maybe someone else can confirm.
Jim
[This message has been edited by jimbolaya (edited 10-10-2014).]
AL87
Report this Post10-11-2014 06:56 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Jim
If it uses fiero trans mounts then everything should just bolt right up.
and maybe redrilling new holes because??? (waiting on a confirmation)
jimbolaya
Total ratings: 114
Report this Post10-11-2014 08:19 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The mounts connect to the 4T60 tran without drilling, but you have to redrill holes in the cradle. Thats where they don't line up, or at least I'm told.
Jim
Edit: I'm hoping to know more tomorrow. If the rain holds out, I'll be trying to at least put my 4T40 on the cradle
[This message has been edited by jimbolaya (edited 10-11-2014).]
jimbolaya
Total ratings: 114
Report this Post10-11-2014 08:32 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
jimbolaya
Member since Feb 2007
Here is a link that has some mount info. http://web.archive.org/web/...s.com/tech/440-4T60/ I'm using this as my source.
Jim
