  3.7 Liter jeep timing issue
3.7 Liter jeep timing issue by ww1139
Started on: 09-04-2014 03:39 PM
Replies: 5 (165 views)
Last post by: benoitmalenfant on 09-05-2014 10:26 AM
ww1139
Report this Post09-04-2014 03:39 PM Click Here to See the Profile for ww1139Send a Private Message to ww1139Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok All i'm new here so maybe i can get some help since i'm a new used jeep owner, What i have is a 3.7 liter engine that i'm replacing all 3 of the timing chains on it. Here is the problem that i'm having I place the Crankshaft sprocket at 6 o'clock and the color link below the dot, and the idler sprocket at 12 with the 2 color links with dot in center below them, the right camshaft with the V6 straight up, and the color link above the dot, and the same on the left the balance shaft dot is up at 12 as well, after that is determined to be correct i set the tensioners, then rotate it 2 times to make sure all is in line with the crankshaft and the idler sprocket, and it is, so then i proceed to reinstall everything, then i start it up, and it runs fine till it warms up then i get a slapping sound sound so then i pull the valve cover to find out that the right camshaft chain is loose enough i can lift it off the sprocket about a 1/2 inch, and of course it starts running rough, just not sure what to do to prvent this and may i add this chain, tensioners, and gears are all brand new, just wondering if the chains was different size, or something i can try to prevent this issue, Thanks to all that reply's back
jaskispyder
Total ratings: 205
Report this Post09-04-2014 03:54 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure how this relates to a Fiero, unless you put that engine in a Fiero
Anyway, are you following a manual when working on this?
dobey
Total ratings: 371
Report this Post09-04-2014 04:01 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you found the wrong forum.
Report this Post09-04-2014 05:19 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum!
Dobey is right.....we have a section called 'Other cars' which may be helpful....but we're hopeless Fiero addicts in this space.
ww1139
Report this Post09-05-2014 07:59 AM Click Here to See the Profile for ww1139Send a Private Message to ww1139Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok sorry, just read a earlier post on jeep, i'll try other cars forum
benoitmalenfant
Report this Post09-05-2014 10:26 AM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
