  Odometer Issue
Odometer Issue by Madscanner
Started on: 09-04-2014 05:11 AM
Replies: 2 (606 views)
Last post by: jaskispyder on 09-04-2014 11:16 AM
Madscanner
Report this Post09-04-2014 05:11 AM Click Here to See the Profile for MadscannerSend a Private Message to MadscannerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi
I have an issue with my Formula. The odometer is not working properly - the 10ths indicator seems to be stuck around 8-9 10ths. It turns but, just as it reaches the point when it should "click over" it seems to slip back to 8, and repeat.
The speedometer works, as does the trip meter.
Any suggestions?
'88 Formula
'85 SE 2M6
'93 Eunos Roadster
'00 Fiesta Zetec S (now sold to fund more Fiero work!)
Report this Post09-04-2014 11:11 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Possibly lube it, or tap on it? Odd problem.
[This message has been edited by 2.5 (edited 09-04-2014).]
jaskispyder
Total ratings: 205
Report this Post09-04-2014 11:16 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can take it apart and check the gears, or swap in a different odo. They are easy to set (yeah, don't trust the ODO reading in a Fiero)
