  fan on when a/c on only.
fan on when a/c on only. by AL87
Started on: 09-04-2014 01:18 AM
Replies: 4 (181 views)
Last post by: sardonyx247 on 09-08-2014 09:43 PM
AL87
Report this Post09-04-2014 01:18 AM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
So, just recently replaced my radiator, everything worked properly when tested after.
just the other day the temp went wayyy up and I did some simple checking around.
I haven't played with the wiring because when I turn the a/c on, the fan also turns on.
I can only figure that the fan switch connection is interrupted somehow
since the a/c activates the fan and everything cools fine after. suggestions?
masospaghetti
Report this Post09-04-2014 08:45 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably your fan temperature switch is bad. You can jumper the two connections and see if the fan comes on.
If you replace it get the 210 degree version, it doesn't let the engine get so hot before it turns the fan on.
Report this Post09-04-2014 11:09 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
In stock form the fan turns on at 235F. Thats not to say every dash temp guage is exactly accurate either. How hot is way up?
AL87
Report this Post09-04-2014 02:19 PM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have the 210 switch from Rodney.
way up means... 240+ upto 260.
I'll try to see what I can do as far as jumping the connector to test.
sardonyx247
Total ratings: 219
Report this Post09-08-2014 09:43 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
easy test, just ground the green/white wire at the temp switch. The fan should come on with the key at that point, if it does bad temp switch, if it doesn't bad wireing.
