  Determining which alternator is right for my 2.5
Determining which alternator is right for my 2.5 by perceptionist
Started on: 09-03-2014 02:16 PM
Replies: 7 (173 views)
Last post by: fierosound on 07-09-2020 06:33 PM
perceptionist
Report this Post09-03-2014 02:16 PM Click Here to See the Profile for perceptionistSend a Private Message to perceptionistEdit/Delete MessageReply w/QuoteDirect Link to This Post
My alternator has failed or is failing. I was planning on grabbing this 100 amp one from Amazon.
http://www.amazon.com/ACDel...&keywords=Alternator
Decent price and I understand AC Delco is a good reliable brand to go with. Their vehicle finder says it is a match for fitting my car (1987 Fiero w/2.5).
But my question is, how does one figure out what the appropriate amperage alternator is necessary for a given vehicle?
I think I read somewhere that you add up all of the values in your fuse box and that should give you a rough estimate. If that is the case, my fuse values all add up to 260! That can't mean I need a 260 amp alternator right?
My car's electrical demands are pretty typical and stock for the most part. The only addition was a 100 watt amp for my stereo added like 8 years ago. And I have the standard Fiero Subwoofer with its stock Fiero sub amp.
I'm on a tight budget for a little while so the $70 price tag on the AC Delco was within reach but I would rather not have any regrets, especially considering the pain it is to swap out my alternator with the engine in the car.
I searched the forums and most of the alternator related posts were pertaining to either the 2.8 or engine swap upgrades.
Thanks for any assistance.
TopNotch
Total ratings: 60
Report this Post09-03-2014 03:43 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
That alternator will do just fine.
mike-ohio
Report this Post09-03-2014 05:43 PM Click Here to See the Profile for mike-ohioClick Here to visit mike-ohio's HomePageSend a Private Message to mike-ohioEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it is an automatic getting out the old alternator is a pain.
I took a bolt off the dogbone and pushed the engine back a bit to wiggle the alternator under the intake to remove it. Watch out for the cooling line to the intake when taking it out this way.
TopNotch
Total ratings: 60
Report this Post09-03-2014 10:09 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
His car is a 4-cylinder, so changing the alternator will be easy in any case.
Fiero.1984
Report this Post07-08-2020 01:51 PM Click Here to See the Profile for Fiero.1984Send a Private Message to Fiero.1984Edit/Delete MessageReply w/QuoteDirect Link to This Post
When I used your link:
https://www.amazon.com/dp/B...hicleType=automotive
It said that this alternator was not for your car. Check it again.
fierosound
Total ratings: 286
Report this Post07-08-2020 02:01 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rockauto - New AC Delco 100 amp $75.79
https://www.rockauto.com/en...or+/+generator,2412?
Total ratings: 458
Report this Post07-08-2020 02:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That was six years ago! I suspect he's dealt with it.
fierosound
Total ratings: 286
Report this Post07-09-2020 06:33 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL.... oops...
