  thermostat house interfers with boost bypass actuator
thermostat house interfers with boost bypass actuator by Charlie1963
Started on: 08-30-2014 08:32 AM
Replies: 5 (138 views)
Last post by: olejoedad on 08-30-2014 02:31 PM
Charlie1963
Report this Post08-30-2014 08:32 AM Click Here to See the Profile for Charlie1963Send a Private Message to Charlie1963Edit/Delete MessageReply w/QuoteDirect Link to This Post
Working on my 3800 swap modifying a stock v6 thermostat housing. I cut out the section with the small hose bibs and now trying to determine the correct orientation of the flange holes with the large coolant hose before welding the pieces back together. The problem is the boost bypass actuator vacuum line fitting is hitting the tstat housing.
I want to keep the bypass so is it possible to move the bypass actuator maybe by modifying the bracket? It would need to move about an inch maybe a little more to be out of the way.
The ECU has already been programmed to keep the bypass but how would the engine run if I remove the bypass without getting the program changed?
thanks
Report this Post08-30-2014 09:54 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't you already start a thread about this?
Yes, yes you did.....
Charlie1963
Report this Post08-30-2014 10:05 AM Click Here to See the Profile for Charlie1963Send a Private Message to Charlie1963Edit/Delete MessageReply w/QuoteDirect Link to This Post
No idea how or why this duplicate appeared, it wasn't intentional.
Lou6t4gto
Report this Post08-30-2014 01:17 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the TITLE of the other thread ?
Lou6t4gto
Report this Post08-30-2014 01:18 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Member since May 2008
nevermind
Report this Post08-30-2014 02:31 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its due to the "Attack of the Double Post Demon"......
It happens....
