  thermostat house interfers with boost bypass actuator
thermostat house interfers with boost bypass actuator by Charlie1963
Started on: 08-29-2014 07:50 PM
Replies: 11 (587 views)
Last post by: Lou6t4gto on 05-19-2019 02:14 PM
Charlie1963
Report this Post08-29-2014 07:50 PM Click Here to See the Profile for Charlie1963Send a Private Message to Charlie1963Edit/Delete MessageReply w/QuoteDirect Link to This Post
Working on my 3800 swap modifying a stock v6 thermostat housing. I cut out the section with the small hose bibs and now trying to determine the correct orientation of the flange holes with the large coolant hose before welding the pieces back together. The problem is the boost bypass actuator vacuum line fitting is hitting the tstat housing.
I want to keep the bypass so is it possible to move the bypass actuator maybe by modifying the bracket? It would need to move about an inch maybe a little more to be out of the way.
The ECU has already been programmed to keep the bypass but how would the engine run if I remove the bypass without getting the program changed?
thanks
Tweeder
Report this Post08-29-2014 10:26 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just used the thermostat housing that came on the 3800 and added a fill point there and the other end attaches to the fiero coolant system.
Report this Post08-29-2014 10:58 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've always used the 3800 t-stat housing with no issues.....fill the block, install the t-stat and housing and the hose. Use the bleeder to burp air from system and keep the coolant tank full....
[This message has been edited by olejoedad (edited 08-29-2014).]
Charlie1963
Report this Post08-30-2014 03:06 PM Click Here to See the Profile for Charlie1963Send a Private Message to Charlie1963Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the responses. I like the Fiero tstat housing for the ease of getting to the thermostat. Since I've already got the housing cut and ready to weld I'm going to try to move the boost valve out of the way by modifying it's bracket.
Lou6t4gto
Report this Post08-30-2014 03:39 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll be watching This. I've got a 2.8 housing ready to cut, but was Also wondering about the By pass valve.
Report this Post08-30-2014 06:20 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is possible to cut and re-weld the thermostat housing to fit but keeping the BBV actuator in place requires very careful modifications. You can use the stock 3800 thermostat housing as Joe has said but you will need a high fill point to pour in the coolant . An easy solution is to use a Moroso inline fill housing with a 25lb cap. IMO, the fill cap or the Fiero housing is important if the engine requires adding coolant.
You can also run using a modified Fiero thermostat housing w/o the BBV actuator but the supercharger will make slightly more noise and you will lose maybe .5-1 mpg of gas mileage. I have run my 3800SC without the BBV for three years with no harmful effects. There are those here who will disagree but a pinned BBV works on this end.
Charlie1963
Report this Post08-30-2014 06:40 PM Click Here to See the Profile for Charlie1963Send a Private Message to Charlie1963Edit/Delete MessageReply w/QuoteDirect Link to This Post
It would appear to be fairly easy to move the bbv solenoid to the left away from the tstat housing by modifying the bracket. Doing so however will change the angle between the linkage and the arm. This will cause the valve to open a little bit less.
It looks like the valve would open about 1/8" - 1/4" less by moving the bbv solenoid. Would this small amount make a difference in the performance of the engine?
Charlie1963
Report this Post09-01-2014 07:56 PM Click Here to See the Profile for Charlie1963Send a Private Message to Charlie1963Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here's the modified bracket. I cut off the original mounting holes then made a new part to weld on.
Here it is installed.
Plenty of clearance now between tstat housing.
Report this Post09-02-2014 03:25 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Creative fabrication. Good work!!!!
Lou6t4gto
Report this Post05-19-2019 01:23 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
no reason to move it if the thermostat housing is made right. just made 3 of them. look at Ebay. ( 3800 thermostat housing) pictures to show you "orientation"
Lou6t4gto
Report this Post05-19-2019 02:09 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Member since May 2008
hope that helps someone
Lou6t4gto
Report this Post05-19-2019 02:14 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
sorry, Guess the "ORIGINAL Question" was how to Move the bypass, oh well.
