  1988 IRON DUKE STARTING ISSUE
1988 IRON DUKE STARTING ISSUE by MrRich
Started on: 08-28-2014 07:10 PM
Replies: 1 (102 views)
Last post by: TopNotch on 08-29-2014 09:57 AM
MrRich
Report this Post08-28-2014 07:10 PM Click Here to See the Profile for MrRichSend a Private Message to MrRichEdit/Delete MessageReply w/QuoteDirect Link to This Post
1. The engine only starts with starter fluid-does not remain running.
2. New injector
3. It is getting a pulse signal at the injector
4. Fuel does come out of the injector when turning over
5. It seems like too rich a flow
6. Cleaned the fuel tank and installed new pump and filter last winter
7. It did fire up and I drove it around but the engine would die.
8. Don't think the gas is bad
9. Haven't tried spraying gas in the throttle body-don't think that's a good idea.
I've changed all the coils and replaced plugs and wires
Does anybody have an idea on this one? I'm open for suggestions
Thanks
MR
TopNotch
Total ratings: 60
Report this Post08-29-2014 09:57 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start the engine with starting fluid, and immediately try opening the throttle a little. If it runs that way, the idle air passage is clogged.
Mount a little round piece of paper on a dentist's mirror (small round mirror on the end of a metal rod). Hold this in the throttle body 2" below the injector, with the paper facing the injector. Have someone crank the engine. Observe the spray pattern on the paper. It should be spraying, not dripping. If it continues to drip after cranking, you have bad injector o-rings.
