  Any E85 experts? - Have some questions for 3800sc Swap
Any E85 experts? - Have some questions for 3800sc Swap by chrissin712
Started on: 08-28-2014 03:09 PM
Replies: 1 (244 views)
Last post by: Justinbart on 08-28-2014 07:09 PM
chrissin712
Report this Post08-28-2014 03:09 PM Click Here to See the Profile for chrissin712Send a Private Message to chrissin712Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just finished cleaning up a 3800sc swap. The donor PCM for 3800sc was tuned for for E85 per the previous owner.
The car seems to idle and run great with E85 in it (Just did a light test drive as I don't want to hurt it) . But I believe I have stock 3800 injectors and a stock fuel pump.
I know I'm a step behind having obtained lots of used parts. But I assume I will need to upgrade both pump/injectors.
If I change to larger injectors and a better fuel pump will I need to re-tune?
Is it even possible to run a 3800 with a stock fiero fuel pump and injectors on e85?
Looking at DW300.
My goal is to drive the car to drive to Fierorama hence the post. Thanks
[This message has been edited by chrissin712 (edited 09-08-2014).]
Justinbart
Total ratings: 119
Report this Post08-28-2014 07:09 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fiero fuel pump wont even come close. Larger injectors will require a new tune. I think stock injectors should get you close to 300hp on e85 if you wanted to wait. The dw300 is a good pump.
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
