  Another wire connection question
Another wire connection question by LornesGT
Started on: 08-25-2014 06:33 PM
Replies: 6 (145 views)
Last post by: my-fiero on 08-26-2014 08:22 AM
LornesGT
Report this Post08-25-2014 06:33 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't see what should connect to the connector located next to the passenger side hinge.
Report this Post08-25-2014 06:41 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The deck lid has the matching plug for that connector.
LornesGT
Report this Post08-25-2014 10:32 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Duh! I haven't put the deck lid back on. Thanks!
my-fiero
Report this Post08-26-2014 06:09 AM Click Here to See the Profile for my-fieroSend a Private Message to my-fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have also a question about a wire
I have this Red/White wire (near the ECM) and there is a extra wire (not original).
I can't find this wire in the manual?
Who can tell me what cable this is?
Total ratings: 290
Report this Post08-26-2014 06:14 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Red and Red/White wires are power wires feeding to the fuse box and headlights. They are not fused. The Purple wire attached to it is thus also unfused and is a fire hazard. If nothing else there should be a fuse holder installed immediately after the wire leaves the larger wire.
[This message has been edited by phonedawgz (edited 08-26-2014).]
Report this Post08-26-2014 07:30 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The red/white wire feeds power to the headlight circuit and IS protected by fusible link B at the battery junction terminal.
The fusible link will not protect the small purple wire in the event of a short in that wire, it should be protected with a small (5-10A) fuse, depending on what it is feeding and the actual gage of the wire.
my-fiero
Report this Post08-26-2014 08:22 AM Click Here to See the Profile for my-fieroSend a Private Message to my-fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks,
that is clear!
yes there is a small fuse at the end of the purple wire.
