  '96 3100 intake vs. '99 3400 intake
'96 3100 intake vs. '99 3400 intake by lou_dias
Started on: 08-25-2014 11:18 AM
Replies: 22 (877 views)
Last post by: carbon on 09-03-2014 02:22 PM
lou_dias
Report this Post08-25-2014 11:18 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
About 2 months ago, I bought a car off of a local craigslist ad. It was an 86 GT with a '96 3100 + 4spd auto swap but it had a bad head gasket. Coolant leaked out the side of the block. Paid $1000
I'm thinking easy fix but then mechanic says to do it right you have to replace the gasket on both heads and deck the heads since they are aluminum...so my initial thoughts on an $800 fix became a $1300 estimate. So I decided to buy a $500 1999 3400. Original motor swap estimate was $1000 so for the $500 cost of the engine, I figured just 3400 it. Well as it turns out, the EGR and temp sensor are different as are the bolt pattern on the intakes.
Mechanic is going to swap the 3100 intake onto the 3400 for simplicity's sake on the swap. Are there any other gotchas I need to worry about?
[This message has been edited by lou_dias (edited 08-25-2014).]
Joseph Upson
Total ratings: 88
Report this Post08-25-2014 11:25 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking easy fix but then mechanic says to do it right you have to replace the gasket on both heads and deck the heads since they are aluminum...so my initial thoughts on an $800 fix became a $1300 estimate. So I decided to buy a $500 1999 3400. Original motor swap estimate was $1000 so for the $500 cost of the engine, I figured just 3400 it. Well as it turns out, the EGR and temp sensor are different as are the bold pattern on the intakes.
You definitely need to go to the 60 degree V6 forum for this as you could actually be cutting performance as a result of the different port sizes that are available at some point during their production.
http://60degreev6.com/conte...DegreeV6-Family-Tree
[This message has been edited by Joseph Upson (edited 08-25-2014).]
hookdonspeed
Total ratings: 131
Report this Post08-25-2014 11:57 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
temp sensor I believe you can just change over, or if not british car conversions sells a sensor for the small port size with the 3wires.
as for the egr, im guessing its the trangle mount on your old one and the long flat on the new one? I believe they use the same connector, just need to get one for the newer style intake. im not sure if going from 3100 to 3400 will need a new tune tho, check with ryan at gmtuners.com to make sure... or if you don't have smog, you can have him tune-out the egr all togather, and just blockoff the ports....
lou_dias
Report this Post08-25-2014 12:28 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not even sure what ECM this setup is running. I paid cash and just had it towed to the mechanic. They told me about excessive frame rust where the cradle bolts up. :/
I'm not worried about [high] performance, just want a winter car so I can park my Formula since my 'race' car is beyond daily-driver material and it also going thru an engine rebuild.
Got a link for that sensor?
Report this Post08-25-2014 02:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't believe I've ever seen that headlight treatment in a GT nose before. Have the headlight openings in the hood been glassed over as well?
As much as I'm intrigued by the look, I suspect that wouldn't pass inspection here as the headlights are below the minimum height restriction.
lou_dias
Report this Post08-25-2014 02:47 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not a fan of it myself. I think there's a kit out there that puts those lights into the factory buckets... Yes, they've been glassed over but nothing that can't be undone...though the wiring has been converted...
It interior was in pretty good shape and it's a swapped car with 4spd auto cheap so I couldn't pass it up. I'm hoping it is running OBD2 so I can study that.
KurtAKX
Total ratings: 128
Report this Post08-26-2014 01:18 AM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you have a much higher probability of being satisfied with the outcome if you do the work yourself.
hookdonspeed
Total ratings: 131
Report this Post08-26-2014 04:16 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
heres the 3wire temp switch
http://www.britishcarconver...3-pin-lx9-ect-detail
heres teh pig tail adapter for if you need to adapt it from the "2" sensors to the one. (1 2pin, and 1 1pin)
http://www.britishcarconver...e-ect-adapter-detail
can tell if its OBD by 1 or 2 by if its running 1 or 2 cranks sensors (one 7x wheel on the crank itself, sensor in the side of the block, and 1 24x sensor in the harmonic dampener, sensor sits behind the pully) 1 sensor is obd1, 2sensors is obd2
also dont think obd1 runs a cam sensor, could be wrong on that tho.
ericjon262
Report this Post08-26-2014 09:57 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
no cam sensor on obd1.
1st class A**hole.
Sigler85GT
Report this Post08-26-2014 10:39 PM Click Here to See the Profile for Sigler85GTSend a Private Message to Sigler85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
but then you wouldn't have anyone else to blame for something going wrong either
KurtAKX
Total ratings: 128
Report this Post08-27-2014 02:55 AM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
which is a pretty good incentive to not screw up!
lou_dias
Report this Post08-27-2014 02:45 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the links. From what the mechanic told me there is a 1-wire sensor on the head going to the temp gauge.
I should have took a few pics of the engine compartment... I'll probably get a chance to do that on Saturday. Turns out there's some major rust in the rear engine mount area that was covered up with sheet metal... That will hold this up another week or so...
dobey
Total ratings: 371
Report this Post08-27-2014 02:56 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or just look at the ALDL connector, and if it's the 16-pin trapezoidal connector, it's OBD-II. If it's rectangular 12-pin connector, then it's pre-OBD-II.
hookdonspeed
Total ratings: 131
Report this Post08-29-2014 09:30 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
but thats `hidden` the sensors and all you can just glance at lol.
lou_dias
Report this Post08-31-2014 01:32 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also found out why they cut the dept of the trunk. They put the catalytic converter near the muffler...well I don't get emissions testing in RI and MA so that will have to be "fixed" at some point...
Also, I got to look at the wiring harness going into the firewall and it looks strangely stock so right now I'm suspecting a '7730 conversion was done since it is running DIS...
[This message has been edited by lou_dias (edited 08-31-2014).]
KaijuSenso
Report this Post08-31-2014 04:59 PM Click Here to See the Profile for KaijuSensoSend a Private Message to KaijuSensoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow those mounts look sketchy. No pictures of the engine though?
lou_dias
Report this Post09-02-2014 09:47 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, you seen 1 3100/3400 you seen them all.
The mechanic had transferred the timing cover and front engine mount over from the 3100. He told me he had to use lower 3400 intake gaskets to mate to the heads...while retaining the upper 3100 intake gaskets. I was able to see the different bolt patterns on the intake and the gaskets. He still didn't have the 3100 intake on but was getting close to putting that on. The mount repair was supposed to be finished Saturday.
All this extra labor will cost an arm and a leg. I am slightly disappointed that it doesn't look like an OBD2 install.
hookdonspeed
Total ratings: 131
Report this Post09-02-2014 10:13 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
toobad you wasn't closer... 3100 to 3400 swap is cake (IMO). and wouldn't have been too bad to go snag a harness from local yard and make you an OBD2 swap.
lou_dias
Report this Post09-02-2014 10:34 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm surprised they even agreed to do the work... Keep in mind they didn't want to mess with the harness and that's why they are swapping intakes.
The 3400 I bought came with the engine harness.
I'll be able to take the oil pump drive gear off the old 3100 and put that on my 3400 hybrid motor finally. I may rebuild the 3100 block and put that in my 93k Formula if/when that 2.8 fails. Would prefer to keep that one looking stock. I've got a DAWG-modded intake I can throw on that car...(screw the EGR).
KaijuSenso
Report this Post09-02-2014 09:06 PM Click Here to See the Profile for KaijuSensoSend a Private Message to KaijuSensoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't understand why this swap is so involved. This is a small port 3100? Why can't you just move the sensors over to the 3400 that are needed to keep running OBD1? Aren't most of the sensors the same but the OBD2 has more of them?
hookdonspeed
Total ratings: 131
Report this Post09-02-2014 10:03 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
kinda what im wondering too, all the ports should be the same and same threads, cept the CTS they did change, but that's an easy fix.. shop doesn't sound like they are qualified to do this as they know nothing about the engines.
lou_dias
Report this Post09-03-2014 08:40 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
IDK. Bolt-patterns did change. Looking at the family tree, there were supposed to be no changes from '96 to '99 but apparently there were. The 3100 has a 6 bolt intake and the 3400 has an 8 bolt where the upper meets the lower. I'll convert the CTS to the 3-wire version later myself. The temp gauge is broken anyway currently. Rather than mess with a harness, they just swapped intakes, that's all I know. I'm going to have all the left-over parts from both motors so I'll look more indept when all is said and done. I just want a running car. I don't care about losing performance.
carbon
Total ratings: 130
Report this Post09-03-2014 02:22 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3100 was changed over to the same intakes/sensors and the same revised timing chain setup as the 3400 in 2000, there was no change in the 3100 mechanically from 94-99. The early 96-99 3400 came after the original 3100 and it got improved/different parts to start with. The only difference between the 2000+ 3100/3400 was the bore.
Edit: And the throttle body size.
The difference in 3100 performance by factory rating is 155-160HP for the small port vs. 170-175HP for the large port.
Edit again: Here is an excellent guide to the differences in the upper intake manifolds for the Gen III 60* V6 engines that has somehow been lost on WOT-TECH's site.
3100/3400 manifolds
[This message has been edited by carbon (edited 09-03-2014).]
