  transmission will not go into park
transmission will not go into park by crashmydaytona
Started on: 08-24-2014 08:38 PM
Replies: 4 (118 views)
Last post by: WICKEDWILDFIERO on 08-24-2014 10:23 PM
crashmydaytona
Report this Post08-24-2014 08:38 PM Click Here to See the Profile for crashmydaytonaSend a Private Message to crashmydaytonaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was attempting to torque my axle nuts today but could not find park to keep the axles from spinning. What am I missing? it is a 4t65hd car is not running im still in the middle of my swap.
Total ratings: 290
Report this Post08-24-2014 09:04 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are in park. One wheel has to be on the ground to lock the other one when in park. Otherwise the diff will allow the other wheel to spin in the opposite direction. You could use a long bar in the wheel studs of the other wheel that hits ground.
Also if needed remember the spare tire has a hole in the middle so you can still reach the axle nut with the tire mounted. Tire bolted on, and a long bar through one of the holes in the spare's rim to keep it from spinning.
[This message has been edited by phonedawgz (edited 08-24-2014).]
WICKEDWILDFIERO
Report this Post08-24-2014 09:28 PM Click Here to See the Profile for WICKEDWILDFIEROSend a Private Message to WICKEDWILDFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trans lever all the way forward should engage park.This will not lock each axle shaft, only the ring gear. Each axle will still turn in opposite directions unless held by something. Good luck...WWFiero
crashmydaytona
Report this Post08-24-2014 10:14 PM Click Here to See the Profile for crashmydaytonaSend a Private Message to crashmydaytonaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info guys. I had no idea thats how a auto transmission worked. Thats 30 minutes of screwing with the shifter ill never get back.
WICKEDWILDFIERO
Report this Post08-24-2014 10:23 PM Click Here to See the Profile for WICKEDWILDFIEROSend a Private Message to WICKEDWILDFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trans lever all the way forward should engage park.This will not lock each axle shaft, only the ring gear. Each axle will still turn in opposite directions unless held by something. Good luck...WWFiero Looks like Phonedawgs beat me to it.
