  window replacement
window replacement by 2268irma
Started on: 08-24-2014 03:07 PM
Replies: 4 (153 views)
Last post by: 2268irma on 08-24-2014 06:42 PM
2268irma
Report this Post08-24-2014 03:07 PM Click Here to See the Profile for 2268irmaSend a Private Message to 2268irmaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had safelite replace my scratched driver door window they installed new stops with screws and plastic nuts instead of rivets twice the stops have popped out and the window has droped down so the door won't close with the window up. They come out and fix it and it lasts a couple of days then the same thing. Any body have a solution fror a permanent fix. They repair it in warrenty but it is a pain. Thanks for any help. P.S. the unscratched window looks great.
Bloozberry
Total ratings: 311
Report this Post08-24-2014 03:25 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used 1/4" diameter bolts with nylock nuts. The lock nuts allow you to keep the bolts from backing out due to vibration even if the nuts aren't super snug (to avoid breaking the glass).
gtoformula
Report this Post08-24-2014 04:37 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ditto what he said. I gutted my doors removing all the tracks and the window motor. Used 1/4" x 1/2"L for the window regulator. Not sure if it was 3/4" or 1"L bolts for the windows. Put them in and forget about it. It will never loosen up again.
jaskispyder
Total ratings: 205
Report this Post08-24-2014 05:35 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
yup, bolts/nuts with lock tite is what I used.
2268irma
Report this Post08-24-2014 06:42 PM Click Here to See the Profile for 2268irmaSend a Private Message to 2268irmaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the help I took it apart and fixed it like you recommened. I didn't think there was room to get behind to put on a nut but I found someone with small hands can't beat the help you get on the forum. Semper Fi to all you ex Marines I've been out since 1959 any other old timers around?
