  Sunroof drain holes
Sunroof drain holes by slink
Started on: 08-24-2014 10:12 AM
Replies: 4 (654 views)
Last post by: theogre on 08-25-2014 08:48 AM
slink
Report this Post08-24-2014 10:12 AM Click Here to See the Profile for slinkSend a Private Message to slinkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am about to install new weather stripping for the sunroof 87 Gt- I have been told that I can drill - 4 - 1/8" holes in the corners for drain holes - has anyone done this and does the water get channled to the ground like I have been told ? Thanks for the help
Lambo nut
Total ratings: 262
Report this Post08-24-2014 10:38 AM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your glass seals to the weather strip properly and the weather strip and rails are sealed to the roof properly, then there is no need to drill any "drain holes".
I never had any problems with mine. A lot of others seem to have a problem with the sealing so they are probably going to tell you need the holes.
Kevin
fierosound
Total ratings: 286
Report this Post08-24-2014 10:52 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Factory Service Bulletin reproduced here:
http://www.fierostore.com/Tech/Default.aspx?Id=326
Calgary time/temp
[This message has been edited by fierosound (edited 08-24-2014).]
Lambo nut
Total ratings: 262
Report this Post08-24-2014 11:25 AM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Figured it wouldn't take long for the band aid "fix" to show up.
Like I said, make sure your tracks are sealed to the roof, the weather strip is sealed to the tracks, and the glass seals to the weather strip and you will be good to go.
Kevin
Total ratings: 568
Report this Post08-25-2014 08:48 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
87 should have the drain holes.
Pull up the seal at rear corners to check.
If roof is leaking w/ drain holes, latch is hosed etc.
