I need help making a decision on blocking the egr or not. I keep getting back and forth answers about it. I've been told it can slightly boost my performance and also got told it wont do anything but kill my gas and make my car run hot. So what is it guys. A do or don't?
Are you modifying the engine for the track use? If not, leave the EGR
(The engine management was designed to work with the EGR, if you remove it, you are only going to make it harder for the engine to work like it is supposed to. The engine was designed for the EGR, keep it).
With that being said, I blocked off the EGR on my V6 because I was getting a stumble at certain RPMs and even replacing everything in the EGR, I couldn't fix it. So I just blocked it off. The car was not driven that much anyway. This is the only car I had to do that to. The rest worked just fine with the factory EGR, including 200K miles on an '88 Formula.
[This message has been edited by jaskispyder (edited 08-21-2014).]
Block it off, remove the whole system (valve and solenoid) and get a prom from reddevil river. The prom chip is programmed to nevrr ask for egr, so the engine never has to adjust fuel or air for it being deleted. Like it never happened.
For street use... And means "race cars" driving to the track...
If car have Emission testing, block off or dead EGR can fail. Example: DE still requires all cars w/ normal tags to pass Emission test.
Q. What vehicles require emissions testing? A: Emissions tests are required on automobiles and on trucks with a manufacturer’s gross vehicle weight rating (MGVWR) of 8500 pounds or less. Exceptions include vehicles manufactured before 1968, diesel-fueled vehicles manufactured before 1997, and motorcycles. DMV conducts approximately 400,000 tests each year.
Ignoring state test... W/o EGR then engine will generate more NOx. More NOx can cause the cat to overheat and fail. Many engines have more aggressive timing when EGR is used. W/o EGR, ECM/PCM can set codes and/or can cause timing issues, knocking or both. Example: 87 and up L4 and others are known knocking problems w/o good EGR. ECM is program w/ good EGR even w/o ECM "seeing" the EGR subsystem.
Race only cars... meaning Cars that will be trailer to the track... then nobody cares much.
Removing EGR to fix a "problem" may make that problem go away, but create others. If it's a street car, leave it. It only functions under cruise. It won't impact performance. A properly working EGR cools the combustion chamber temps and helps gas mileage. Removing it without reprogramming the ECM can actually cause problems with lean spark knock. Programming it out can hurt gas mileage and doesn't improve performance.
I removed mine and added the chip, the only difference is the intake doesn't soot up and access to work in that area is outstanding. I would leave it installed if you have DEQ in your area.
