  3.1 96 auto idle (not in a fiero)
3.1 96 auto idle (not in a fiero) by tomsablon
Started on: 08-21-2014 06:22 AM
Replies: 2 (98 views)
Last post by: tomsablon on 08-21-2014 12:49 PM
tomsablon
Report this Post08-21-2014 06:22 AM Click Here to See the Profile for tomsablonSend a Private Message to tomsablonEdit/Delete MessageReply w/QuoteDirect Link to This Post
it's no in a fiero although I know you guys can help figure this out. 96 cutlass ciera.
when my friends wife starts the car every now and then it starts with a high idle. without touching the pedal she shuts it off and turns It back on and everything is normal. the tsp was replaced about a year ago because but it didn't help. some times it happens when she's on the road. we did a scan and it said tsp. could it be the cruise control(they don't use it) ? or possible the throttle cable? the idle air valve was also replaced. maybe a connector or something? I've never seen it happen. I hope you all don't mind I ask for help on this forum.
Total ratings: 291
Report this Post08-21-2014 10:33 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The ECM normally zeros the IAC when the key is turned off and then presets it for the next start. I am suspecting that the ECM is having troubles doing that. Since you have replaced the IAC, my next suspect is that there is carbon in the IAC passage that is blocking it from moving freely.
tomsablon
Report this Post08-21-2014 12:49 PM Click Here to See the Profile for tomsablonSend a Private Message to tomsablonEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the reply. we had ryan rechip a matching ecm because we thought that might be the problem. but after a couple of weeks it was back to it's misbehaven. now and then it will keep the rpm up going down the highway even though it didn't do the fast idle ghost at start up. and it will make the tps code.
