  84 se build
84 se build by concorde01
Started on: 08-18-2014 04:49 PM
Replies: 7 (168 views)
Last post by: concorde01 on 08-21-2014 10:28 PM
concorde01
Report this Post08-18-2014 04:49 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
soi striped apart my 84 inside and out. getting ready to put on a fastback clip. i was planing on a 3.4 swap. but have been reading alot about the 3800 sc. i want peoples ideas and opinions on both. i know the 3800 is more work but is the power worth it? also will it work with my 4spd?
concorde01
Report this Post08-20-2014 07:19 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
so i finishaed pulling out the old harness today. from the front firewall back. i need a write up on instaling the new harness. from either a 85 or 86
Neils88
Total ratings: 56
Report this Post08-20-2014 07:54 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
(I'm a 4.9 guy) The 3.4 will be a slightly simpler and cheaper swap, but there are great resources and support for both. You need to decide what you plan on doing with the car to decide what will make you happy. You can't go wrong with either, but if you really want power and all out performance, then you are better off starting with the 3800sc. Be aware that the supercharger sound is not for everyone...you'll be listening to it a lot, so you should do a search for some 3800sc videos (taken from within the car) to get a feel for what it sounds like.
There are issues with the 84 that need to be dealt with. Sounds like you are already doing a harness swap. I'm not sure what else, if anything may be required.
Good luck! ...and keep the thread going!
concorde01
Report this Post08-20-2014 07:55 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
i evently intend to swap to 88 cradles starting in the back first
concorde01
Report this Post08-21-2014 10:06 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
well got a guy wants to buy my duke. soo......i need a full right up for puting a 3.4 into my 84
Report this Post08-21-2014 10:23 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You will want to read this one.............
https://www.fiero.nl/forum/Forum3/HTML/000026.html
concorde01
Report this Post08-21-2014 10:26 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
ty. i am also reading and printing out this
http://gafiero.akroncdnr.com/docs/84v6.pdf
concorde01
Report this Post08-21-2014 10:28 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
Member since Jul 2014
also i intend to use the complete 3.4 and only change the starter. oil pan and timing cover parts. keeping the nicer looking intake. so any help with what computer is needed would be great ty
