  Should I have a 17" spare tire in the front compartment....
Should I have a 17" spare tire in the front compartment.... by Gokart
Started on: 08-16-2014 04:57 PM
Replies: 11 (395 views)
Last post by: tshark on 08-23-2014 05:26 PM
Gokart
Total ratings: 94
Report this Post08-16-2014 04:57 PM Click Here to See the Profile for GokartSend a Private Message to GokartEdit/Delete MessageReply w/QuoteDirect Link to This Post
...if I'm running full time with 17" rims now? Especially considering I have a sage chin spoiler molded to the front facia?
Probably be an issue getting it to fit in the spare tire location though?
Marc
Arns85GT
Total ratings: 202
Report this Post08-16-2014 05:11 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't carry a spare at all. I use CAA 200 mi. (AAA)
Arn
Gokart
Total ratings: 94
Report this Post08-16-2014 05:20 PM Click Here to See the Profile for GokartSend a Private Message to GokartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Arn
Good point! I have triple A too so maybe it'll be used for some other stuff
1fast2m4
Report this Post08-17-2014 12:09 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just make sure your spare rim clears your brakes and the outside diameter matches the other four wheels
1986 SE 3800SC/4t65eHD (12.871@104.96)
HX-40, FrozenBoost I/C, 80lb injectors & E85 Coming soon.....
Gokart
Total ratings: 94
Report this Post08-17-2014 03:55 PM Click Here to See the Profile for GokartSend a Private Message to GokartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking I could just keep the 15". It might just get me to a service station. I imagine I wouldn't have an issue if I blew a rear tire. I doubt I'd "bottom out". Even though I run different sizes in the rear, if I blew a front I could move one of the 17" rear tires there and put the doughnut on the rear?!
1fast2m4
Report this Post08-17-2014 04:20 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rim diameter doesn't make much of a difference unless you have a big brake kit that you need to clear. other than that I'd only be concerned about the overall height of the entire assembly
I'd match your spare size to your drive wheels. the only thing that could be hurt by running different size tires would be the Differential
[This message has been edited by 1fast2m4 (edited 08-17-2014).]
Gokart
Total ratings: 94
Report this Post08-17-2014 04:23 PM Click Here to See the Profile for GokartSend a Private Message to GokartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking I'll throw it on and see what happens....just in case so I'm prepared in a pinch!
Thanks for the replies
jon m
Report this Post08-18-2014 04:47 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm using 18" with 225x40 tyres on - they are 5mm bigger in diameter than the 15" stock wheel and tyre so wont make much difference if you had to use the space saver wheel.
Gokart
Total ratings: 94
Report this Post08-18-2014 05:08 PM Click Here to See the Profile for GokartSend a Private Message to GokartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great to know thank you! The only issue I can see having is up front where I have the chin spoiler and I'm about 4 inches from the asphalt
If I blow out a front I'll just move a back one there and then use the spare in the back
thanks for all the replies!
[This message has been edited by Gokart (edited 08-18-2014).]
Gokart
Total ratings: 94
Report this Post08-18-2014 05:10 PM Click Here to See the Profile for GokartSend a Private Message to GokartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gokart
Member since May 99
Sorry... Double post!
2268irma
Report this Post08-23-2014 01:52 PM Click Here to See the Profile for 2268irmaSend a Private Message to 2268irmaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got around the spare problem with my 17s by going to Mich run flats no spare needed.
tshark
Report this Post08-23-2014 05:26 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
