  Isuzu tranny 5th gear
Isuzu tranny 5th gear by Csjag
Started on: 08-14-2014 09:35 AM
Replies: 1 (133 views)
Last post by: olejoedad on 08-14-2014 09:42 AM
Csjag
Report this Post08-14-2014 09:35 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my 85 2M4 5 speed all the gears shift fine except 5th, there is a slight grind shifting into 5th unless I shift really fast. I do know that my slave cylinder is not working well and I plan on replacing it with Rodneys but my question is: Since fifth gear is overdrive does it require more clutch movement, is that why there is no grind in the other gears?
Thanks
Report this Post08-14-2014 09:42 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doesn't require more clutch travel, fix the hydraulics and bleed, if still grinds adjust linkage, if still grinds perhaps synronizers.
