  Radiator coolant question
Radiator coolant question by Wannafiero
Started on: 08-12-2014 09:46 PM
Replies: 7 (366 views)
Last post by: Wannafiero on 08-13-2014 01:43 PM
Wannafiero
Report this Post08-12-2014 09:46 PM Click Here to See the Profile for WannafieroSend a Private Message to WannafieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
After more than a year of waiting, and over two years of thinking, I finally bought an 88 Formula with a 3.4 pushrod. I have never worked on a car before, but want to learn, so I can pass this knowledge to my son. I figured with all the support in this forum, I will be in good hands if I get in over my head.
My first newbie question relates to coolant. The car does not have any leaks and did not overheat during it's 5 hour trip home, but I noticed coolant in the reservoir tank was about 1.5 inches lower than the add line when not running. I want to add coolant to get to the add line but was not sure if I can just add coolant to the reservoir tank directly, or do I need to add more coolant using the burping process? Or should I just leave it alone. I have completed searches, but did not find anything about just adding coolant.
What is a good coolant to use?
I also need to figure out why the car is a bit idle loopy from 1k to 1.5k upon start up. But I have found some possible answers using the search feature. I will take one step at a time.
I appreciate your time.
Report this Post08-12-2014 09:58 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Add 50/50 premix universal coolant to the overflow reservoir. Fill to halfway between 'ADD' and 'HOT'.
Lopey idle is not uncommon, not a big deal.
Enjoy your Formula and take care of it. It is a wonderful automobile.
PaulJK
Total ratings: 237
Report this Post08-13-2014 02:34 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to check the coolant when the car is HOT. When cooled off, the coolant level should be below the line as you saw it. Right now, I'd just leave it alone. DO NOT start messing with the radiator caps because if you open the system, you may let air in and cause yourself a problem where there wasn't one.
You can use any of the yellow-green coolants. Do NOT use the orange stuff.
This is called "hunting idle" and SEARCH will turn up a lot of things to try.
rogergarrison
Total ratings: 551
Report this Post08-13-2014 09:39 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes use any univeral antifreeze, not any red or specialized ones. I buy unmixed myself, pour half into another gallon jug, add water to both, and I have 2 gallons of premixed for the cost of one gallon of premixed. I dont worry too much about being on the level lines in the overflow. I just keep it so its between the lines and never have any problems. Except for convenience, I never figured out why people buy premixed for nearly the same price as unmixed. I see it at the grocery store too, people pay MORE for the little half cans than the full size cans right next to them. Someone was a marketing genius...double your profits.
Report this Post08-13-2014 09:56 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I do this too, but I make sure to use distilled water, it doesnt have minerals which cause corrosion like normal tap or garden hose water.
I also recommend getting a service manual, or downloadable here tho I dont see an 88 service manual.
http://www.fieronews.net/fusion/downloads.php
Wannafiero
Report this Post08-13-2014 10:46 AM Click Here to See the Profile for WannafieroSend a Private Message to WannafieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
So just to be clear, I can add additional coolant directly to the reservoir wihout having to go though the whole burping process? I am concerned about getting air in the system and causing problems.
TopNotch
Total ratings: 60
Report this Post08-13-2014 11:24 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Adding coolant to the reservoir does not open the system, and no air will get in.
Wannafiero
Report this Post08-13-2014 01:43 PM Click Here to See the Profile for WannafieroSend a Private Message to WannafieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you very much for the help, I am going to add a little coolant to the reservoir this weekend.
