  Rotates but wont start
Rotates but wont start by GizmoKershner
Started on: 08-12-2014 01:46 AM
Replies: 18 (452 views)
Last post by: GizmoKershner on 08-14-2014 08:25 PM
GizmoKershner
Report this Post08-12-2014 01:46 AM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Compression test was fine, fuel pressure is good, was no spark, but replaced ignition coils and fixed that. Still won't start, suggestions?
Total ratings: 290
Report this Post08-12-2014 01:53 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year? What engine?
You do have spark?
Does the tach rise to 200 RPM during cranking?
Any story as to what just happened that it doesn't start? Maybe like it sat for 5 years? Or just ran yesterday?
[This message has been edited by phonedawgz (edited 08-12-2014).]
GizmoKershner
Report this Post08-12-2014 03:50 AM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
88 2.5 4 cylinder. It sat for three days, was running fine. Had to crank for awhile to start at first, but now won't start at all. It has spark now.
Total ratings: 290
Report this Post08-12-2014 04:28 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
While cranking look down the throttle body. Is it injecting fuel?
GizmoKershner
Report this Post08-12-2014 10:13 AM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's getting fuel and spark. Here's a question for you. It was running really rough because the egr was stuck open and the mechanic that was working on it blocked it off and said I didn't need it because there is no emissions here. Could that cause the no start?
Report this Post08-12-2014 04:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck with that plan. 87 and up DIS engines often will have problems w/o good EGR.
Why? GM programed DIS ECM to assume a good EGR or engine can, likely will, knock.
OE type EGR listed in... See my Cave, Emissions
EGR = No start? Maybe. Check for other vacuum leaks.
Also See my Cave, DIS Ignition
Bad plugs/wires can cause big problem, Including "fake" EGR problems.
TopNotch
Total ratings: 60
Report this Post08-12-2014 05:28 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look through the oil filler cap while someone cranks the engine, to see if the rockers move. If not -- broken timing gear.
GizmoKershner
Report this Post08-12-2014 07:49 PM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took off the egr and it didn't look like it was blocked off at all, but he said he did and that fixed the previous problem of shaking with low acceleration. Also I cannot find where he put the vaccum line running off the egr.
NW-Fiero
Report this Post08-12-2014 09:25 PM Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the mechanic removed the vac line the EGR solenoid will have an open connection.
Mark
' 85 2m6 3.4PR
In the Great Northwest!
[This message has been edited by NW-Fiero (edited 08-12-2014).]
TopNotch
Total ratings: 60
Report this Post08-13-2014 11:03 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's no EGR solenoid on the 4-cylinder. Also, the EGR can't be tested by applying vacuum to the vacuum line fitting on it. The only way to test the EGR on a 4-cylinder is to run the engine, slowly increase RPM's, and see if the diaphragm in the EGR valve rises. It is controlled by a combination of vacuum and back pressure, and neither alone can open it.
GizmoKershner
Report this Post08-13-2014 11:35 AM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
He put a cap on the vaccum out of the intake I found. Also I found that the injector is not squirting fuel upon cranking, but fuel is making it to it.
TopNotch
Total ratings: 60
Report this Post08-13-2014 03:11 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
How do you know fuel is getting to the injector? Did you remove it? If you remove it right after an attempt to start, you should get quite a squirt of gas (in your face if you're hovering over the throttle body).
GizmoKershner
Report this Post08-13-2014 05:42 PM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's exactly what I did. Haha minus the squirt to the face, I had a rag. My friend is bringing a multi meter over to see if it's the injector or the relay.
NW-Fiero
Report this Post08-13-2014 06:48 PM Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Starting Fluid Spray ....any effect.
Sorry missed the 88 Duke. post
Mark
' 85 2m6 3.4PR
GizmoKershner
Report this Post08-13-2014 09:30 PM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Relay is good, just tried starting fluid with no effect. Starting to think the injector is actually good, but I didn't see fuel coming out when cranking it and I do believe a cone of fuel is suppose to come out. Also retested the spark and there is none. Ignition module is good, coils, plugs and wires I just replaced. Any thoughts on to what else will cause no spark?
GizmoKershner
Report this Post08-13-2014 09:32 PM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
GizmoKershner
Member since Jul 2014
Also I fixed the egr issue. I had to rely on my video on my phone to test for spark before so it is possible it wasn't sparking earlier.
GizmoKershner
Report this Post08-13-2014 09:36 PM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
GizmoKershner
Also also, the rockers do move through the oil cap while cranking.
TONY_C
Report this Post08-14-2014 10:33 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
Crank Sensor?
GizmoKershner
Report this Post08-14-2014 08:25 PM Click Here to See the Profile for GizmoKershnerSend a Private Message to GizmoKershnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's exactly what was wrong. Haha. Checked the crank position sensor, aka hall effect switch and it had a hairline crack I missed. Replaced and running like new. Thank you all for your help!
