shift light in the cluster by mmeyer86gt/gtp
Started on : 05-23-2014 12:09 AM
Replies : 14 (303 views)
Last post by : Will on 05-28-2014 08:22 AM
May 23rd, 2014
mmeyer86gt/gtp Member Posts: 3876 From: galt, ca Registered: Sep 2001
how does it wire up to light up? is the computer grounding the wire to complete the path?
12:09 AM
phonedawgz Member Posts: 17104 From: Green Bay, WI USA Registered: Dec 2009
quote Originally posted by mmeyer86gt/gtp: Is the computer grounding the wire to complete the path?
Yes
02:33 AM
so just ground pin 1 and it turns on correct?
09:28 AM
TopNotch Member Posts: 3537 From: Lawrenceville, GA USA Registered: Feb 2009
The shift light is only good if you want to drive for maximum fuel economy. If you want to drive for maximum fun, the light will be on most of the time.
02:20 PM
Patrick Member Posts: 38694 From: Vancouver, British Columbia, Canada Registered: Apr 99
quote Originally posted by TopNotch: If you want to drive for maximum fun, the light will be on most of the time.
That's been my experience as well.
The shift light is nothing more than a distraction. IMO the fewer flashing red lights in the cluster the better.
[This message has been edited by Patrick (edited 05-23-2014).]
02:26 PM
Fierotoyboy Member Posts: 265 From: Rochester Hills, MI US Registered: Feb 2005
I always just remove the bulb for that thing. I agree it's just a distraction.
03:20 PM
CC Rider Member Posts: 2037 From: Cameron Park, Ca Registered: May 2001
Not for economy in this case.
Used as indicator that sport shift is engaged
[This message has been edited by CC Rider (edited 05-27-2014).]
03:46 PM
quote Originally posted by CC Rider: Not for economy in this case.
What case?
quote Originally posted by CC Rider: Used as indicator that spot shift is engaged
What is "spot shift"? Who has it?
03:57 PM
Purple86GT Member Posts: 1592 From: Ontario, Canada Registered: Mar 2012
I think he meant sport shift. (like in the GTP trans).
04:02 PM
Yup yup so us pin 1 on the cluster positive or a ground
05:18 PM
May 25th, 2014
just ground pin 1 and the light turns on!! worked like a charm
04:17 PM
Blacktree Member Posts: 20770 From: Central Florida Registered: Dec 2001
Yep, power from the fusebox comes through another pin (don't remember which number). So, for example, you could use an RPM activated switch to ground pin 1 and have a "real" shift light, while keeping a stock looking gauge cluster.
[This message has been edited by Blacktree (edited 05-25-2014).]
04:46 PM
quote Originally posted by Blacktree: ...you could use an RPM activated switch to ground pin 1 and have a "real" shift light
Hey, I like the sound of that. So, who's got instructions?
05:32 PM
May 27th, 2014
2 relays needed One for the ground and one for the light
05:00 PM
May 28th, 2014
Will Member Posts: 14284 From: Where you least expect me Registered: Jun 2000
quote Originally posted by Blacktree: Yep, power from the fusebox comes through another pin (don't remember which number). So, for example, you could use an RPM activated switch to ground pin 1 and have a "real" shift light, while keeping a stock looking gauge cluster.
That's what I did.
08:22 AM
