  engine swap?
engine swap? by vincent
Started on: 05-22-2014 05:29 PM
Replies: 8 (470 views)
Last post by: vincent on 05-25-2014 12:11 PM
vincent
Report this Post05-22-2014 05:29 PM Click Here to See the Profile for vincentSend a Private Message to vincentEdit/Delete MessageReply w/QuoteDirect Link to This Post
hi,
is there a possibility to swap the 2.8 engine for a 3.1 , 3.4 or 3.8 without modification (without removing or changing engine mounts etc?)
kind regards
Purple86GT
Total ratings: 62
Report this Post05-22-2014 05:41 PM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the 3.4 is as simple as it gets. Not sure but I think you need to drill new holes for the starter mount.
the 3800SC is a bit more involved but bang for the buck, well worth it. Lots of documentation here and many people willing to help.
Lou6t4gto
Report this Post05-24-2014 02:39 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've done both the 3.4 And the 3800SC. the 3.4 doesn't get any easier (pull out the 2.8 bolt in the 3.4) (except drilling the 2 holes for the starter), and can have more "seat of the pants" power. (Not like the 3800SC), But it is SOOO MUCH EASIER, and ALOT, ALOT Cheaper.
Got deep pockets ? (always cost twice what you "Figure") And a lot of Down time.
In the end, Yea, the 3800SC is great, but expensive (Even doing everything your self)
Report this Post05-24-2014 11:00 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Swapping in a 3.4 from a 93-95 Camaro or Firebird is as easy as pulling your stock engine and putting it back in. Rodney's starter relocation jig is designed for the do-it-yourselfer. He's gone to great efforts to be sure it works for you.
Keep in mind that if your original engine isn't an 88, you will have to use a flywheel or flexplate from an 88 Fiero or from a 3.1 equipped car if you install a 3.4. The flywheel or flexplate should not have chunks of weights welded to its backside.
vincent
Report this Post05-25-2014 04:19 AM Click Here to See the Profile for vincentSend a Private Message to vincentEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanx for the great information.
i gonna search for an 3.4 engine :-)
if it's that simple , is there a how to on the forum?
grtz
Old Lar
Total ratings: 214
Report this Post05-25-2014 08:47 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can get a new 3.4 crate engine from several sources.
Report this Post05-25-2014 08:54 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
3.4 engine swap from a link on www.gafiero.org Tech Tips, Other offsite tips
http://fiero34swap.eleventenths.org/
Grantman
Report this Post05-25-2014 09:06 AM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have a 3 speed automatic I would strongly suggest doing a 4T60 swap at the same time. Adds work to the swap but really improves the driveability of the car and gas mileage goes way up.
1986 Fiero GT fastback SC3800 3.4 pulley, LS1 TB
1986 Fiero GT Fastback 3.4Lpr with 4T60 - SOLD
1998 Jeep Grand Cherokee with "big boy" 5.9 motor
1983 Honda Goldwing 1100 Interstate
vincent
Report this Post05-25-2014 12:11 PM Click Here to See the Profile for vincentSend a Private Message to vincentEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have an 2.8 v6 1987 with manual 5 speed.
is it also possible to do a swap with the camaro 3.1 engine?
