  transmission issue still with 87 2.5
transmission issue still with 87 2.5 by kmelic2037
Started on: 05-22-2014 07:24 AM
Replies: 2 (183 views)
Last post by: TopNotch on 05-22-2014 09:31 AM
kmelic2037
Report this Post05-22-2014 07:24 AM Click Here to See the Profile for kmelic2037Send a Private Message to kmelic2037Edit/Delete MessageReply w/QuoteDirect Link to This Post
need help. going to get the car towed home today from the inspection station where after passing all state tests the 5 spd issuzu transmission locks up and has to be pushed out onto the lot. Can't find any rhyme or reason but it is locked up internally after full overhaul and only 45 miles on the new motor and trans. Is there substitute manual transmission I could put in the car? done with this Issuzu. Not that mechanically inclined to do an automatic with removing the steering column and all that. Is an adaptor needed for the 2.5 and if so where to I obtain one? What manual transmission could be swapped with very little technical skills.
As Always I appreciate everyones help and comments, but if this one doesn't work MY wife is having Good Will pick up the car....
Mike W
Report this Post05-22-2014 08:46 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Isuzu is a good transmission. Maybe you should be done with whoever did the 'overhaul'.
TopNotch
Total ratings: 60
Report this Post05-22-2014 09:31 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Please describe your problem. Exactly what is "locked up" -- the wheels, the shifter, etc.?
If the shifter is locked up, remove the cables from the levers on the transmission and try to shift through the gears there at the transmission.
