  trans problem
trans problem by sgosser
Started on: 05-19-2014 11:16 PM
Replies: 1 (74 views)
Last post by: Gall757 on 05-20-2014 11:08 AM
sgosser
Report this Post05-19-2014 11:16 PM Click Here to See the Profile for sgosserSend a Private Message to sgosserEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a quick question about my transmission. Just installed 2.8 with 4 speed in my 85. been bleeding the clutch many times. I finally have every gear but 2nd. the shifter hits a wall when trying to go to 2nd. it doesn't grind. it just stops dead. I have brand new cables and have adjusted them according to directions on here. I am pretty sure an old vss gear fell off in the trans because it was missing when I checked. I am wondering if it has lodged causing no 2nd gear or if I need to keep bleeding the system. I am leaning toward that gear because I can't even get the shifter down enough to make it grind. any opinions? thanks. I do have another 4 speed
[This message has been edited by sgosser (edited 05-20-2014).]
Report this Post05-20-2014 11:08 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your issue is probably inside the transmission, but disconnect the cables and move the lever on the transmission just to be sure.
