| | | quote | Originally posted by codex653:
By ground strap do you mean the big fat ground cable that comes directly off the battery and bolts into the engine block? As far as I know the starter is grounded through the engine block, yes? |
yes it is, just where is yours bolted to the block? if it is bolted to a accessory mount make sure the accessory mount is clean and those bolts are tight as well if it is just grounded to anywhere else. make sure everything is clean between both ends of the ground at the battery and the block.
Steve
